69 metering valve problem - *pics - Team Camaro Tech
post #1 of 6 (permalink) Old Jun 6th, 01, 11:26 AM Thread Starter
Below are two links to pictures of two different valves , the larger one doesn't fit the bracket right and the blind hole / threaded holes are reversed.
The new looking one is what I just received as being correct for a 69 Power Disc setup , I can't find a close up picture anywhere to tell if this smaller one is correct , I thought it was supposed to be exactly like the bigger one.
You can see that the body of the valve is bigger in relation to the nut , does anyone have this smaller one one their car (and sure that it's correct ?)
Is there a close-up picture ANYWHERE of a stock 69 master cyl./metering valve ?
http://albums.photopoint.com/j/View?...nce=0&res=high
I'm gettin' pretty sick of trying to find the correct one here...
Thanks,
RSSS69conv is offline
post #2 of 6 (permalink) Old Jun 6th, 01, 06:27 PM
The one that is larger is correct for a 69 power disc system. I just rebuilt my entire system complete, and thats the one I have, which I`m sure is original to the car,as I`ve owned the car for 25 years. I rebuilt my own, as there is really nothing in it but a seal, valve and spring. I`m sure you can do it too. The smaller one may be from power drum or manual disc. Good luck, Dave.
Earl L-89 is offline
post #3 of 6 (permalink) Old Jun 6th, 01, 06:37 PM
David Pozzi
davidpozzi's Avatar
Here's a 69 booster and metering valve. http://ourworld.compuserve.com/homep...boost_side.jpg
The older valve in your photo looks like it.
Why not use the old one? They can also be rebuilt by Master Power.
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
65 Lola T-70 Chev 350
Can Am Vintage Racer
[This message has been edited by davidpozzi (edited 06-06-2001).]
davidpozzi is offline
post #4 of 6 (permalink) Old Jun 6th, 01, 07:08 PM Thread Starter
Thanks ! , I knew the bigger one was it , I've seen it too many times , but Rick's sent this smaller one today and I knew it wasn't right when I seen it. I thought maybe there was a second version or something.
Can't use the "correct" looking one because the blind/threaded holes for the bracket are reversed and spaced wrong for the stock half-round bracket , but mainly because the side hole for the brake line / flare is wrong. It's the same size as the one in the big nut , and it's supposed to be the next bigger nut / thread size.
No problem rebuilding one if I could find it , there's nothing to them.
post #5 of 6 (permalink) Old Jun 7th, 01, 08:32 AM
mccorry's Avatar
Where do you get the new seals to rebuild these units?
Steve McCorry - Central Ohio Camaro Club
'69 Camaro RS/SS-350 - Daytona Yellow
'95 Camaro Z-28 - Sebring Silver
click here to see my webpage ---> www.mindspring.com/~mccorry (updated 5/18/01)
mccorry is offline
post #6 of 6 (permalink) Old Jun 7th, 01, 10:01 AM
David Pozzi
davidpozzi's Avatar
Here's a photo of the seal inside. There is an O ring for the cap too.
Someone sent me this photo, I don't have a better one. I have not had one of these apart myself.
If this seal is just an O ring, you can probably get one easily. You can't quite see the whole seal in the photo.
http://ourworld.compuserve.com/homep.../metervins.JPG
If you have a four speed car or no choke. you might be able to leave this valve off completely.
My friend did and has no problems.
67 RS 327
[This message has been edited by davidpozzi (edited 06-07-2001).]
