How do you remove the ignition switch? - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 9th, 00, 05:45 PM Thread Starter
I am having trouble removing the ignition switch from my '67. I have already loosened the threaded bezel to the point that it just spins. What is the procedure for using the pin hole next to the key slot? I'm sure that I am making this much tougher than it actually is.
[This message has been edited by mhock (edited 04-09-2000).]
mhock is offline
post #2 of 3 (permalink) Old Apr 9th, 00, 06:08 PM
Lonnie
If I remember right, put the key in and turn it left to the acc. position. Push a pin into the hole and turn more to the left and it pops out. It has been awhile so I might be wrong.
67 410sb 11.63 @117.6
Lonnie67 is offline
post #3 of 3 (permalink) Old Apr 9th, 00, 06:11 PM
Cool
Go ahead and tighten the bezel back, then put in the key. Here is the trick, turn key to the left on accessories then put a paper clip end inside the hole until it stops, keep pressure on the clip and turn key all the way left. You might have to work at a few times.
Once it rotates then pull out with key.
67 SS
70 Z/28
camaroguy is offline
