69 ss - Team Camaro Tech
post #1 of 5 (permalink) Old Dec 22nd, 99, 03:13 PM Thread Starter
Greg
did ss camaros come out with 10 and 12 bolt rears thanks
gregmontgomery is offline
post #2 of 5 (permalink) Old Dec 22nd, 99, 04:42 PM
I think that Camaro SS 350's could have been ordered with 10 or 12 bolt rear ends. The 396's had 12 bolt posi rears
Silver69 is offline
post #3 of 5 (permalink) Old Dec 23rd, 99, 03:41 PM
Charley
clill's Avatar
All 67-70 SS Camaros had 12 bolt rear ends.
clill is offline
post #4 of 5 (permalink) Old Dec 24th, 99, 09:43 AM
all ss 396's had 12-bolts, but not all were posi's. (i know because unfortunately mine doesn't)
this was taken from the Camaro Research Group web site:
http://www.camaros.org/suspen.shtml#12-Bolt
Q: [05-May-1999] New: What models received 12-bolt axles?
A: 12-bolt axles were installed on all SS-396s, all SS-350s (with possible 1969 exceptions noted below), all Z-28s, plus the other models itemized below.
Note: GM documentation indicates that early 1969 SS-350s and LM1s with automatic transmissions may have received a 10-bolt rear axle, with a 12-bolt axle optional. The extent of this is, as yet, not well known. Both 10-bolt and 12-bolt models seem to exist and CRG is still researching this. Please help clarify this by submitting your vehicle data.
In addition, 12-bolt axles were installed on the following cars:
L30/M20 cars from approximately Dec 1966 through the end of the 1968 model year.
All models with the 1969 factory 4-wheel disc brake JL8 option.
1969 cars with the LM1 engine. Use on the manual transmission cars appears certain. Use on the automatic transmission cars may have varied and may be subject to the same usage issues being researched for SS-350 in 1969 and described in the Note above.
To see a pic of my car, click here... pages.prodigy.net/mtbmtb/rf396ss.jpg
[This message has been edited by mike brown (edited 12-24-1999).]
mike brown is offline
post #5 of 5 (permalink) Old Dec 31st, 99, 09:01 AM
Kurt S
Kurt S's Avatar
I'll also add that CRG also has data on 12 bolts in (2) 67 6 cylinder cars and one LF7 (327/210hp). They may have been using up the 12 bolts without radius rod brackets.
Kurt S.
www.camaros.org
Kurt S is offline
