68 Z-28? how can i tell? - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 13th, 00, 06:10 AM Thread Starter
I bought a 68 years ago and i dont know how to tell if it was a true Z-28? it has the emblems, no build sheet, just the vin# and the cowl tag, which dont help me. is there any secret #'s anywhere? or options that only came with the Z-28? any info would be very appreciated. thanks, and drive like you stole it!!hee please e-me.
jokiry is offline
post #2 of 3 (permalink) Old Apr 13th, 00, 07:09 AM
Jokiry:
There is a lot of things to look for, Z/28 wher only coupes, they had a 302cid 290Hp enngine coded MO, original 12 bolt rearend, multileafs rear springs, 4 spd manual shifter (M21 or M22), front disc brakes, 15" x 6" wheels, take a look at the sticker tire in the glove box door size should be E70 x 15, dual exhaust system (look for the hanger on the rear end), etc.
Take a look at the CRG site, specially at http://www.camaros.org/diffs68.shtml
Hope this helps.
Moris is offline
post #3 of 3 (permalink) Old Apr 14th, 00, 05:28 PM
Jeremiah
Guest
Posts: n/a
They were also all fast ratio steering.If it is it will have Different steering nuckles PNs 3954879 and 3954880.The pitman arm will also have a different casting # 3953227. The duall exhaust hangers are a good way to tell if it was at least a performance optioned car.the bracket is welded to the frame rail just behind the drivers side rear tire.Plus the usual like a twelve bolt, multi leafs,disc brakes.Tach was not mandatory.Bye a book and start checking codes and options.The Definative 67/68 Z/28 fact book is great. Good luck.
