Welding subframe seams - Team Camaro Tech
post #1 of 8 (permalink) Old Apr 28th, 01, 03:49 PM Thread Starter
m22
Talking
I am wondering what the benefits of welding the seams on the subframe are. I can guess that its an increase in rigidity but i'm trying to decide wether or not to do it while my sub is off the car.My car will remain total stock as far as the drive train goes ([email protected] h.p.)
m22 is offline
post #2 of 8 (permalink) Old Apr 28th, 01, 04:35 PM
David Pozzi
davidpozzi's Avatar
I did mine while out last year.
I feel it's more preventative to keep existing welds from breaking when the car is driven hard.
I doubt it will increase rigidity.
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
65 Lola T-70 Chev 350
Can Am Vintage Racer
davidpozzi is offline
post #3 of 8 (permalink) Old Apr 28th, 01, 04:46 PM
I think overall the benefits are that the factory welds are somewhat questionable. I know on my own subframe in my '68 one side had fairly decent welds where the other side it looked like my 8 year old did it. I had the frame sandblasted and then went over all of the welds. I would personally weld it off the car. Even after sandblasting the seams overlap and junk is still in there so expect some of it to come burning out. I'm lucky enough to have a freind with a degree in welding so mine is pretty stout! Check it out: http://albums.photopoint.com/j/View?...nce=0&res=high
I know on mine I just wanted a little extra piece of mind and I had the frame out anyway for painting so it wasn't all that much more time. I did have it blasted one more time after all the welding then POR-15 (2 coats) and 1 coat inside. Turned out great!
MStarmer
MStarmer is offline
post #4 of 8 (permalink) Old Apr 29th, 01, 06:21 AM
I weld mine. I think there is an abnormal amount of twist on the frame when you beat on em like I do (drive em like you stole em). It only takes an hour or two. And like MStarmer said, The original welds are a little questionable.
69er
69 Camaro 454
71 Nova 454
If your not living on the edge then your taking up too much space
69er is offline
post #5 of 8 (permalink) Old Apr 29th, 01, 09:15 AM
I don't know how much welding the subframes will help but while you are there put subframe connectors in. I put a set in my old Nova wagon and it made the thing a completely different car. Much better in every way I don't know why the factory didn't do it couldn't have cost them that much
oger is offline
post #6 of 8 (permalink) Old Apr 29th, 01, 09:26 AM
I just sandblasted my sub frame,If yours looks like mine,(Quality Control musta sucked on the sub frame line in 69,Mine looks like a dog ate exlax and crapped on all the seams.Im for sure gonna weld mine up.
69 Camaro SS 350 4 speed
55 Belair Sedan Pro Street 355 auto 9''
gene stills is offline
post #7 of 8 (permalink) Old Apr 29th, 01, 06:40 PM
I welded mine up solid before I sand blasted and painted it too.
Geezer
Geezer is offline
post #8 of 8 (permalink) Old Apr 30th, 01, 12:57 AM
Cool
A word to the wise, m22.
Sandblast, weld seams as suggested, and if you're going to install frame connectors, then before install, assemble car and take to frame shop, have car measured and adjusted to be square, Then have a four-wheel (thrust-angle) alignment done. Get the body square with axles.
You'll appreciate the extra effort put into it.
Everett#2390 is online now
