fuel pump question? - Team Camaro Tech
post #1 of 3 (permalink) Old Jan 5th, 01, 08:32 AM Thread Starter
Angry
The reason I figured my engine to be a hi-po 327 is because the fuel pump went out recently and I at first bought the fuel pump for a 350 when I got it home I found out that the fuel pump was wrong so I took it back and replaced it with one for a 327 and it worked perfectly and mached the old fuel pump. Then I was looking around on the internet for engine codes and found out that It was either a 302, or a corvette/camaro
hi-po 327, I found these results on two separarte internet sites, the names I do not know.
hi-po327 is offline
post #2 of 3 (permalink) Old Jan 5th, 01, 09:33 AM
Thumbs up
Post your #'s on the tag team section on this site, you're sure to get an informative response. I assume you have the 0010 block, so just post the #'s off the deck, they will be the #'s needed to tell exactly what the motor is out of......also, you might want to pull one of your valve covers and get your head casting #'s, those will help also.......KZ
John D. Smith
69' SS/396
www.geocities.com/kz1000ltd
kz1000ltd is offline
post #3 of 3 (permalink) Old Jan 6th, 01, 04:47 PM Thread Starter
I found on the moretec website that the block number 3970010 could be a 69' 302 or a 69'to 80' 350 the other codes on the engine are c5f121802 and v1121tyz and on the harvey racing engines website the numbers show a corvette/camaro hi-po 327.
hi-po327 is offline
