67 Convertible pump..rebuild? - Team Camaro Tech
post #1 of 3 (permalink) Old Dec 28th, 00, 05:06 PM Thread Starter
Looking for some advice on the convertible pump. I am restoring a 67 ragtop and when I put power to the pump, no action. I removed the pump, and opened it. The armature seemed to be seized. Actually, a little WD-40, and the armature was freed and it looks like everything should work fine. Any advice on new brushes? Proper cleaner for magnets and armature? Proper reassembly instructions?
Anything will help....beats a new pump if I can get this one working again. I have lots I can spend my money on.
Also, what is the recommended fluid for refilling the pump and lines?
Thanks.....
Doug....Neighbor to the North
67 ragtop....middle of restification.
[This message has been edited by howser57 (edited 12-28-2000).]
howser57 is offline
post #2 of 3 (permalink) Old Dec 29th, 00, 03:06 AM
I just went thru the same thing with mine, and I bought a new pump. Didnt want the hassles of getting the old pump going and not working once the interior was in. I got it from that place in Fla. called 'Convertible Specialties'. Nice pump. What to put in it, they recommend power steering fluid. I think the assembly manual says that you can use tranny fluid, take your pick. Also, they said that they dont rebuild them.
67 Camaro SS Conv.
70 Challenger R/T Conv.
[This message has been edited by ragtopman (edited 12-29-2000).]
ragtopman is offline
post #3 of 3 (permalink) Old Dec 29th, 00, 06:17 PM
Doug I used hydraulic oil on my top system works great, as far as the motor goes try a auto electric shop the one here in Windsor rebuilds them check the price first might be cheaper and better to replace it with a new one. Hope this helps Garry
Garry Gagnier is offline
