coil wires - Team Camaro Tech
post #1 of 5 (permalink) Old Jun 3rd, 00, 06:08 AM Thread Starter
Ok guys I need some help. I haven't been getting and spark to my plugs, so I bought a new Accel super stock coil and I want to be sure that I wire it up right. I think the dist. wire goes to the - side am I right? then I have three wires comming out of my firewall two are connected together into one connector do these go to + side? then the other wire which is brown in color,does it go to the - side? thanks for any advice. The car that this is on is a 70 z28 # matching 4 speed
zgator is offline
post #2 of 5 (permalink) Old Jun 3rd, 00, 07:31 AM
The single wre from the distributor comes from it to the coil negative - side.
There should be a single connector with two wires attached to it, and this is the voltage feed, needs to be on the coil positive + side.
Last wire isn't known, but may just be tach wire. If so, it goes on the coil negative - side. If the tach wire is connected to the positive side of the coil, you won't get fire from the coil. If it isn't an ignition related wire, and is connected to either coil terminal, will probably not allow fire.
IgnitionMan is offline
post #3 of 5 (permalink) Old Jun 3rd, 00, 07:33 AM
Jody
camcojb's Avatar
The brown wire is the tach wire. Hook it to the - terminal with the dist. wire as IgnitionMan said.
Jody
camcojb is offline
post #4 of 5 (permalink) Old Jun 3rd, 00, 08:42 AM Thread Starter
Thanks guys. One other thing I forgot to tell ya'll about. For some resason I had a condenser attached to my coil. Why did I do that? It was on the + side
zgator is offline
post #5 of 5 (permalink) Old Jun 3rd, 00, 09:17 AM
<BLOCKQUOTE>quote:</font><HR>Originally posted by zgator:
Thanks guys. One other thing I forgot to tell ya'll about. For some resason I had a condenser attached to my coil. Why did I do that? It was on the + side<HR></BLOCKQUOTE>
the condenser is for radio interference
69 rs conversion is offline
