bent control arms - Team Camaro Tech
post #1 of 7 (permalink) Old Apr 12th, 01, 11:06 AM Thread Starter
Angry
I took both lower control arms to a shop to get the ball joints and bushings pressed out. I received them in damaged condition. Both arms are bent where the holes are for the bushings. It's hard to explain, but if I got the flanges straight again, would the control arms be fine to use?
Kevin Imh is offline
post #2 of 7 (permalink) Old Apr 12th, 01, 12:43 PM
Yes, but what you got to do is use a steel rod (I believe 1/2")and run it through both bushing. It has to slide through both of them easily.
69er
69 Camaro 454
71 Nova 454
If your not living on the edge then your taking up too much space
69er is offline
post #3 of 7 (permalink) Old Apr 12th, 01, 01:40 PM
David Pozzi
davidpozzi's Avatar
They should have used a spacer between the A frame halves to prevent bending them.
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
davidpozzi is offline
post #4 of 7 (permalink) Old Apr 12th, 01, 02:09 PM Thread Starter
Lightbulb
Thanks for the help, I never thought of the rod trough the two bushing holes.
post #5 of 7 (permalink) Old Apr 12th, 01, 02:12 PM Thread Starter
Smile
<BLOCKQUOTE>quote:</font><HR>Originally posted by davidpozzi:
<HR></BLOCKQUOTE>
The funny thing is is that they didn't use a press, they used a hammer. The metal is all messed up; it looks like someone hit it with a big metal hammer because the metal has marks all over it; marks that only a hammer would do. Thanks for the reply.
post #6 of 7 (permalink) Old Apr 12th, 01, 02:15 PM Thread Starter
Smile
<HR></BLOCKQUOTE>
post #7 of 7 (permalink) Old Apr 13th, 01, 06:17 PM
That shop sounds like a bunch of knuckleheads. Sounds like they don't do much suspension work.
I got real lucky when I brought my lower arms to have the old ball joints pressed out and my new ones installed. I had seriously bent one of the arms a while back when I had hit something in the road. Not only did the shop straighten it out for me at no charge, when I pulled out my wallet to pay for the rest of the work they told me "Don't worry about it". I was shocked!
my69gofast is offline
