Simple question about making keys. - Team Camaro Tech
post #1 of 8 (permalink) Old Jun 4th, 00, 11:33 AM Thread Starter
I have an 89 camaro rs, with the pass-key system in place, how do I have extra keys made for my car? I never knew that I had such a feature until today when my car did not start with copied keys that I had made. Do I have to go straight to a dealer or is there someone else that can do it for me? Thanks.
Ashram
Ashram is offline
post #2 of 8 (permalink) Old Jun 4th, 00, 11:43 AM
David Pozzi
davidpozzi's Avatar
Your keys have a pellet in the stem that has a specific resitstance value, the car's system reads the resistance value and allows the car to start when satysfied. If the pellet makes contact poorly it can cause trouble. The system allows two tries I think, then disables starting for 10 minutes. Then you can try again.
Check with the dealer, or a locksmith, a good one, not the hardware store guy.
The older I get, the faster I was!
davidpozzi is offline
post #3 of 8 (permalink) Old Jun 4th, 00, 11:46 AM Thread Starter
Thanks for the information, I appreciate your explaination of how it works, I know some things about cars, but not a whole lot of specifics.
Ashram
Ashram is offline
post #4 of 8 (permalink) Old Jun 4th, 00, 06:53 PM
when we had copies made for our 89 pontiac formula, we had it done by the local gm dealer. it was pricy, but no other way. i think you might need vin number or something, my dad did it, so the details arent clear. if i were you, just to be safe, i would drive your car so they can gather any other nessecery info, eliminating extra trips.
shelbyz28 is offline
post #5 of 8 (permalink) Old Jun 4th, 00, 07:53 PM
Any GM dealer can do it but u r correct they r very expencive...I think they charge around 30-40 bucks....grab your yellow pages and call a few GOOD lock smith places and see if they do it....most larger lock smiths do do them and i think i was charged 25 bucks for mine
BAD97Z28CONV is offline
post #6 of 8 (permalink) Old Jun 4th, 00, 10:21 PM
I know it disables a good security feature but I have seen kits to bypass the pass key feature in several of the hotrodding mags, just a thought
Gregs67 is offline
post #7 of 8 (permalink) Old Jun 12th, 00, 06:57 PM
Wink
look inside the Ign tumbler, (where you put the key) and u will see 2 pieces of metal.
take a pick and slightly bend the tabs towards the center(increases pressure).
also try cleaning the tabs (in tumbler)and the resistor in the key with a razor blade(scrape it once).
try that first then you must goto a G.M.dealer(trust me/i work there)
and get your key resistance read,if thats the problem(replace it/new one cut).
also may have 2 replace the ign. tumbler also. another one of G.M.'s awesome ideas
gsegan is offline
post #8 of 8 (permalink) Old Jun 12th, 00, 07:53 PM Thread Starter
My pass key system works fine with keys made with the resistance pellet. The keys that I had made were from wal-mart, without the resistance pellet. So I have to go straight to a GM dealer to have copies made...Thanks everyone.
Ashram
Ashram is offline
