Trans Slipping - Team Camaro Tech
post #1 of 2 (permalink) Old Apr 30th, 01, 03:31 PM Thread Starter
From a stop my 67 hesitates for a split second then engages. Could this be the trans slipping or maybe a bad u-joint. If a u-joint how do you tell for sure? Thanks in advance for any reply.
Gambler is offline
post #2 of 2 (permalink) Old May 1st, 01, 05:27 AM
mbrekke's Avatar
Gambler
The u-joints are easy enough to check, but you have to get under the car. Just grab the drive shaft at the u-joint and try to move it up and down and side to side. There shouldn't be any play in the u-joint at all. You got enough tranny fluid in it? Good luck!
mbrekke is offline
