Harmonic balancer - Team Camaro Tech
post #1 of 2 (permalink) Old Jun 6th, 00, 04:04 PM Thread Starter
Has anyone stripped the threads out of the crankshaft where the harmonic balancer bolts on to it in a 350? Need a strong fix, any suggestions?
ANDREW is offline
post #2 of 2 (permalink) Old Jun 6th, 00, 04:58 PM
David Pozzi
davidpozzi's Avatar
You could drill it and tap for a 1/2" bolt. You need a starting tap and a bottoming tap. They should be high speed steel and of good quality, you don't want to break off a tap in there.
The common vermont american type are not good enough.
If it's a steel crank follow the above.
If it's a cast crank it'l be softer and a cheaper tap might work.
The older I get, the faster I was!
davidpozzi is offline
