750 too big? - Team Camaro Tech
post #1 of 7 (permalink) Old May 1st, 01, 06:01 PM Thread Starter
Hey guys I just bought a 89 RS (couldn't afford a 1st gen) with t-tops. It was originally fuel injected but it was changed over to a carburated 350. the engine has a 750 holley and i was wondering if it was too big for my setup.
350
9.5:1 compression
Not sure what kind of heads, but they have been shaved and have had $400 worth of work done to them (3angle port)
edlebrock RPM intake
Headers
Dynomax exhaust
is this carb to big?
should a go with a 650?
thanks
Tom Ziokowski is offline
post #2 of 7 (permalink) Old May 1st, 01, 09:16 PM
For the street...the 650 will be the ticket.
The 650 will have mucho better response when properly set-up....
The 750 will work out OK ...but 650 is better.
Is this a 4150???
CHEERS
Chris
cerrem is offline
post #3 of 7 (permalink) Old May 1st, 01, 09:28 PM
I have the same thing going on. The 750 just seems to be a bit of overkill, and is sluggish when you plant your foot on it. I am building a 400, and I knew I would be doing this project when I bought the carb, so that is my logic to the purchase, heh.
BreathWeapon is offline
post #4 of 7 (permalink) Old May 2nd, 01, 01:35 AM
Bill
Tom,
If it is a vacuum secondary carb, keep it. One of the nice things about vacuum secondary carbs like the Holley 3310 series is that they size themselves to the motor. At low rpms, the secondaries do not open and the carb is basically a 2bbl. The 750 Holley is probably on a million or so 350's running just great....unless ou have money to throw away on another carb, I would try it first. Now if it is a double pumper, I would change.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
1973 Z-28 ..one family car...Brother bought it new in 73
BillK is offline
post #5 of 7 (permalink) Old May 2nd, 01, 02:03 AM Thread Starter
Thanks guys for all your help. It is a vacuum secondary. I don't know the model number but i will find out. i am going to have to keep the 750 for now because i am BROKE!
thanks
post #6 of 7 (permalink) Old May 3rd, 01, 06:47 AM
JohnZ's Avatar
The Holley "List Number" is stamped on the front side of the choke air horn - if you post it we can decode it.
JohnZ
'69 Z28 Fathom Green
JohnZ is offline
post #7 of 7 (permalink) Old May 3rd, 01, 10:28 AM
i have that exact carb. duel feed, single pump, vac secondaries. the number on the horn says 3310. only mine has 74 jets. i believe the stock jets are a 72.
68rs-conv is offline
