69 a/c removal - Team Camaro Tech
post #1 of 6 (permalink) Old Jan 1st, 01, 11:30 AM Thread Starter
I have a 69 with a/c. I would like to remove the set up since I dont have the money to restore the system. Is there a big difference in an a/c firewall vs. a standard firewall? I was thinking I could run a non a/c heater box and have a little heat. If that wont work I would make covers for the firewall. Maybe some day Ill have enough for a vintage air system. Thank You
neonblue 69 is offline
post #2 of 6 (permalink) Old Jan 1st, 01, 04:16 PM
On my 80 Z I started that same prodject.I found some big differences the heater core was different.The hole for the top tube is in a different place but if you remove the inside assesambly you will see the place were the other pipe would go.Also the plastic fan blades are shorter.the holes were the none A/C cover would be are different what I did is a friend of mine is really good with fiberglas so he cut the original A/C box down and redid it and it came out really nice.I hope that will help you out some
Hollywood Z28 is offline
post #3 of 6 (permalink) Old Jan 1st, 01, 05:07 PM
neonblue69, what do you need to fix your present system? There isn't that many 69 A/C cars around. It's kinda nice to have a/c in a 69.
Bob
69 Coupe LeMans-Blue
Frame-Off Resto, ZZ-502/502 Crate, A/C, Griffin Rad., March Serpintine Sys., 2800 Stall with Hughes T-400, Currie 9" with 370 Gears.
http://www.geocities.com/mobiletools1/Mvc-440f.jpg
http://www.geocities.com/mobile_tools01/
mobiletools is offline
post #4 of 6 (permalink) Old Jan 1st, 01, 05:08 PM
mccorry's Avatar
The firewall penetrations are COMPLETELY different for a factory A/C car. Removal would involve welding in a patch panel....
Steve McCorry - Central Ohio Camaro Club
'69 Camaro RS/SS-350 - Daytona Yellow
'95 Camaro Z-28 - Sebring Silver
click here to see my webpage ---> www.mindspring.com/~mccorry (updated 12/22/00)
mccorry is offline
post #5 of 6 (permalink) Old Jan 2nd, 01, 03:12 PM
neonblue69,
The easiest and trickest way I have ever seen anyone "remove" the A/C is this:
I saw a guy who used the standard A/C evaporator box and cut it parallel to the firewall about 4" away (about equal to the releif where the heater fittings come out). Then, he fabricated a pannel to fill the hole, mounting a set of gauges (water temp, oil pressure, vacuum, tac, etc.). It also gave him a nice spot to mount an aftermarket ignition box. All of your diag. gauges are right there in the engine comp. while you are tuning! I thought it was very tasteful. It sure beats modifying the firewall! And you can use the original A/C heater core. It does the job by getting most of the bulk out of the way.
Now, I would never condone chopping a BB evaporator box (although they make them repro now), but small block boxes are a dime a dozen, and you could use an already damaged one.
Now for the important question: do you have the original A/C hoses? If you do, and they are in good working shape, I would like to purchase them. Let me know.
Keith
'69 RS/SS 502 (an original BB, A/C car)
awsm502 is offline
post #6 of 6 (permalink) Old Jan 4th, 01, 01:57 PM Thread Starter
Thanks for all your input. The system just needs to be gone thru. What money I have saved I really want to pull the motor, detail the engine compartment, new wiring etc. And go thru the brakes. I dont plan on welding on the firewall in cause I want to put it back to stock. I do plan on keeping all parts. That way they stay with the car. Thanks again for all your replies.
