B&M Pro Stick shifter in a 69... - Team Camaro Tech
post #1 of 6 (permalink) Old May 2nd, 01, 06:28 AM Thread Starter
Has anyone installed a B&M Pro Stick shifter in a 69? I am removing the console and horseshoe shifter to install a B&M and I'm wondering if I need to modify the floor to bolt it in and if the trans cable routing to the TH350 will change.
Thanks!
RFrenette is offline
post #2 of 6 (permalink) Old May 2nd, 01, 03:16 PM
I put a Pro Stick with aluminum cover in the original opening for the horseshoe. Bolted to the floor through new holes I drilled, you will have to make a new opening for the cable though. Other than that pretty easy job, make sure if you going to use the console to mark your holes with the shifter in the console already, don't guess where it will sit. Check out this link, I borrowed the idea from this guy. http://www.camarogenerations.com/sheets.html
Doug Thiel
69SS
dthiel is offline
post #3 of 6 (permalink) Old May 3rd, 01, 02:08 AM Thread Starter
That is AWESOME! I love how it sits in the console!
I hear the owner of the car, Anthony, created some shims to raise the shifter in the console. Did you have to do the same?
Do you have a pic of yours?
Thanks!
[This message has been edited by RFrenette (edited 05-03-2001).]
post #4 of 6 (permalink) Old May 4th, 01, 09:29 AM
Talking
This is what I have been looking for!
Ray McCarthy is offline
post #5 of 6 (permalink) Old May 4th, 01, 03:03 PM Thread Starter
What are you installing Ray?
I'm going from a PowerGlide to a TH350 and replacing the horseshoe w/ the B&M. I didn't think I'd be able to keep the console but this looks great!
Rob
post #6 of 6 (permalink) Old May 5th, 01, 09:56 AM
I do not have any pics of my shifter, however it looks just like Mr. Sheets' does and it is very nice to not miss a shift. I did shim the base of the shifter, both front and back to get it to sit in there a little higher. Glad I could point you to the fix.
Doug Thiel
69SS
dthiel is offline
