Differential problems - Team Camaro Tech
post #1 of 4 (permalink) Old Jul 6th, 01, 10:31 PM Thread Starter
I have a grinding noise in my rear axel and I get a loud banging noise when I put my car into drive...what do I do?
1986z28tpi is offline
post #2 of 4 (permalink) Old Jul 7th, 01, 04:52 AM
The grinding noise could be a bad wheel bearing, and the poping noise is a broken transmission mount which is common on those cars.
68 SS 396
camaroguy is offline
post #3 of 4 (permalink) Old Jul 7th, 01, 06:35 AM
Freddie
Is the pinion seal leaking? If it is the pinion bearings are probably bad. Take it to someone who knows how to set op a ring & pinion set and have them check it out.
'69 RS/SS396 pro street
427/4spd/9"
Byars Performance
Building High Performance Rear Ends
big gear head is online now
post #4 of 4 (permalink) Old Jul 7th, 01, 07:53 AM
It may even be the pinion nut backing off...I fought that problem on a neighbors 73 chevy truck for the longest time...come to find out the threads on the pinion were shot and the pinion nut would back off every 1000 miles or so...causing the exact same problem.
375hp 78 Chevy truck
77 Chevy Nova
95 Chevy Lumina 3.4L
and building a 78 Nova
travis is offline
