Big Block heating problems, Belt fan or Elect. Fan? HELP - Team Camaro Tech
post #1 of 6 (permalink) Old Jun 12th, 00, 05:45 AM Thread Starter
Chris
I like to drive around town in my 69 camaro. It is a big block producing over 500 HP. Do you think I should go to an electric fan setup or stick with my belt driven setup? I have a 17" flex fan, Griffen aluminum radiator, weiend water pump, and 160 degree thermostat. My car was over heating bad at stopping points, but this is without a FAN SHROUD! I'm going to put on the fan shroud soon here, you think this will solve my problem, or do I NEED AN ELECTRIC FAN.
I just don't know where to go from here!
Thanks for any help!
I just want to drive this beast, and let'em rip!!!!
Procharged69 is offline
post #2 of 6 (permalink) Old Jun 12th, 00, 06:41 AM
Jody
camcojb's Avatar
I have a 72 Camaro with an app. 500 h.p. 406. I started with a Be Cool aluminum radiator, Flowkooler pump, 17" fan and new factory shroud, and tried 160 and 180 thermostats. Sitting at idle in traffic the temp approached 225 but would run great as long as you were moving. I had a Spal electric fan from another project so I figured I'd try it before switching to a good clutch fan set-up (my next option). I removed the factory shroud and installed the Spal fan set-up. The car will not go over 195 (which is where the thermostatic control turns the fan on) and as soon as the fan starts you can watch the temp drop to 180. It worked for me.
It's all about airflow and the 17" fan w/shroud at idle didn't make any. You could feel in front of the radiator when the engine was idling and feel some air movement, but not much. The Spal fan has MUCH more airflow through the radiator at idle. I think a clutch fan w/shroud would also work well.
[This message has been edited by Camcojb (edited 06-12-2000).]
camcojb is offline
post #3 of 6 (permalink) Old Jun 12th, 00, 06:50 AM Thread Starter
Chris
Where can I get one of these Spal fans?
Do you have any reccomendations on which one to get if this is going to be my primary fan?
Do I need a FAN SHROUD with one of these SPAL FANS?
post #4 of 6 (permalink) Old Jun 12th, 00, 07:37 AM
Vintage air sells spall fans and one of there own that even flows more air, but you need more room. Get yourself a Streetrodder magazine, there are a bunch of places that sells them and other types too. I'm running two spal fans on my 468 and they do the job.
68 468 700R4, and here it is;
mutert23
MarkM is offline
post #5 of 6 (permalink) Old Jun 12th, 00, 06:56 PM
I tried the spal fan for about a day. The fan was great. The part that I didn't like is the loud whine that it made. I couldn't even here my motor over the sound of the fan at idle. I returned it and bought two Bosch fans ($10.00 each from the junk yard) that were originally on a Saab Turbo. They are quiet and provide good air flow. I am running a 427 in a 68, with a 4 core small block radiator, so far no problems. I have not run it on any hot days though.
Rick
rickmack is offline
post #6 of 6 (permalink) Old Jun 13th, 00, 03:01 PM
Thumbs up
I myself have a 67 coupe with a 454 bb producing just over 500 hp.All i have is a bill mitchell 5 core rad,no shroud,and a mr. gasket 14" electric fan. i have never gone above 205.
Tpantoulias is offline
