Rear Leaf Springs - Team Camaro Tech
post #1 of 9 (permalink) Old Jan 2nd, 01, 06:06 AM Thread Starter
Looking for some feedback on the use of "Eaton-Detroit" rear leaf springs. My all Original Mono leaf coupe needs some help. I have talked with Eaton-Detroit and they will either sell me a mono setup that lacks the original taper or sell me a multi leaf. The other solution is to send them my old mono springs and they will check them and attempt to re-heat and re-arch. Has any one purchased a mono or 4 leaf setup from them, If so do they look somewhat original in appearance, Or has anyone sent them their old Mono's for a re-arch. If so I would like to hear your thoughts.... If I can't go original I likely will go 4 leaf.
[This message has been edited by wacky174 (edited 01-02-2001).]
wacky174 is offline
post #2 of 9 (permalink) Old Jan 2nd, 01, 09:49 AM
Thumbs up
I HAVE THE MONO FROM EATON THEY LOOK ORIGINAL
AND THEY PERFORM GREAT
68 RS ORIGINAL 327 4 BARREL 650 CFM EDELBROCK
HEADERS,2CHAMBERS FLOW MASTERS,3" PIPE.
12 BOLT REAR END 331 GEARS
PUMA68 is offline
post #3 of 9 (permalink) Old Jan 2nd, 01, 10:31 AM Thread Starter
Thumbs up
Puma68 How about ride height are you happy with the height. Are the new Mono's about the same or a bit higher ??
wacky174 is offline
post #4 of 9 (permalink) Old Jan 2nd, 01, 11:12 AM
my mono's are the same height as the originals and iam happy with them
PUMA68 is offline
post #5 of 9 (permalink) Old Jan 5th, 01, 02:10 PM
Dan
Thanks for the info.
[This message has been edited by DanBnis (edited 01-05-2001).]
DanBnis is offline
post #6 of 9 (permalink) Old Jan 5th, 01, 04:14 PM
Thumbs up
i bought my eaton 5 leafs from ricks camaro and i cannot tell them from the originals.
helen is offline
post #7 of 9 (permalink) Old Jan 7th, 01, 05:34 AM
I was a bit disappointed with my Detroit-Eaton springs. They look great now but I had to send them back because the arch was too low by 1.25"! I had originally ordered a spring with 1" drop from stock but received ones with 2.25". I was not happy to have to pay for the shipping to have them re-arched.
Joseph
Joseph is offline
post #8 of 9 (permalink) Old Jan 9th, 01, 03:59 AM
The Eaton monos I am putting in right now are a little wider than the originals. You wouldn'd see a difference from stock without close exam and measuring. The only thing that the wider middle area seems to affect is having to trim the new Energy Suspension poly pads. The edges of these pads look like they were designed to come up on the sides of the stock leafs. The new monos fit snugly in between the sides of the perch instead of having the gap like the old ones.
I haven't driven these yet, but will be finished installing today. The ride height looks pretty much identical to the stock height before.
backfire is offline
post #9 of 9 (permalink) Old Jan 9th, 01, 10:09 AM Thread Starter
Smile
Backfire
Thanks ..........
<BLOCKQUOTE>quote:</font><HR>Originally posted by backfire:
<HR></BLOCKQUOTE>
wacky174 is offline
