67 Console Gauge replacement - Team Camaro Tech
post #1 of 3 (permalink) Old Jun 18th, 00, 09:44 AM Thread Starter
I would like to replace these gauges with some which are more accurate but I would like to keep a sort of stock appearence. Is there anyone who makes gauges which can be put in the exsisting housing but have modern technology and accuracy.
RickB1B is offline
post #2 of 3 (permalink) Old Jun 18th, 00, 12:19 PM
David Pozzi
davidpozzi's Avatar
I think Moroso or someone makes a guage pod that goes on your console with better guages.
Your guages can be replaced by a repair shop, they can put new innards in them but I don't know about reading any better.
I'd thought for years about at least adding numerals to mine.
I don't think you will really see any better accuracy unless you get a bigger sweep to the guage. In that case, you will not be able to fit two guages per hole.
Now, if you have a particular problem with one guage, maybe you could concentrate on that one and get it working better. Maybe a sender or bad connection is it. There is a voltage regulator that goes back there to power the fuel, oil, and temp guages that can be changed.
http://www.fix-a-gauge.com/index.html GUAGE POWER SUPPLY
Just my opinion.
Let me know if you find a better way.
The older I get, the faster I was!
davidpozzi is offline
post #3 of 3 (permalink) Old Jun 18th, 00, 04:39 PM
stevo camaro's Avatar
Wink
Hey rick, I'll take your old gauges if you don't want them.
67 SS 396,4-sp
67 RS 327,4-sp
72 RS 350/350
69 4X4 suburban 350,4-sp
73 3/4 ton 454/400
http://www.geocities.com/stevocamaro
stevo camaro is offline
