Engine Stalls under hard braking - Team Camaro Tech
post #1 of 4 (permalink) Old May 2nd, 01, 04:58 PM Thread Starter
I have a question. I just finished installing my new baer 4 wheel disk brakes. When I was seasoning the rotors with the hard stops the engine would die. When I restarted it from rolling it would appear that it had flooded since I could see a lot of black exhaust. I checked my floats and they were a little high, but after adjusting them it still wants to die under hard braking. I have a 427, single plane intake, 850 DP. I have an electic fuel pump, not a high volume or anything with no regulator. Any suggestions would be appreciated.
Kent
67 SS 427
kwissman is offline
post #2 of 4 (permalink) Old May 2nd, 01, 05:36 PM
David Pozzi
davidpozzi's Avatar
Install a plastic "vent whistle" on the rear fuel block to prevent fuel slosh into the carb.
Or extend the vent tubes higher.
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
65 Lola T-70 Chev 350
Can Am Vintage Racer
davidpozzi is offline
post #3 of 4 (permalink) Old May 3rd, 01, 06:19 PM
My camaro is a '69 with a midly built 350. It had the same problem and when I was almost hit in town by a lasy that was blinded by the sun in her eyes, I slammed on my brakes and then tried to crank my car for 5 minutes. ANYHOW!!! I started to reas up on the subject, and found that my problem was badly needed jet extensions. After I installed them, with the correct float, I could stand on my brakes, and the car would not even stutter.
speedball1969 is offline
post #4 of 4 (permalink) Old May 3rd, 01, 06:32 PM
If you have enough room put a piece of hose between the front and rear vents with a hole in the top of the hose. We used that for years on the drag cars and had no problems.
oger is offline
