Weird backfiring - Team Camaro Tech
post #1 of 9 (permalink) Old Jul 8th, 01, 02:35 PM Thread Starter
I just came off of my first real long drive with my car. (69, 327, m21)
I went approx. 30 miles on the highway at around 75mph. I know, that's peanuts compared to some of you guys, but it was my first real "long haul" in my new car.
Anyways, now when I'm down in first or second gear, I'm getting little backfires periodically. They're not a nuisance, but they're a "new" noise that I didn't have before.
Any ideas, as to what they might be??
All info is greatly appreciated!
THNX!
monte1214 is offline
post #2 of 9 (permalink) Old Jul 8th, 01, 03:42 PM
David Pozzi
davidpozzi's Avatar
If it's kinda a "sneeze" when you are really out of the throttle, you may be too lean on cruse mixture or have some pluggin of the carb air bleeds, maybe a float level that is too low.
If it were under power, I'd suspect timing that is retarded.
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
davidpozzi is offline
post #3 of 9 (permalink) Old Jul 9th, 01, 09:36 AM
This could be a possible timing problem. Make sure none of your spark plug wires are arching on your headers if you have em. I have notices any type of miss in these cars can possily create a backfire
js67ss350 is offline
post #4 of 9 (permalink) Old Jul 9th, 01, 11:05 AM Thread Starter
Thanks alot guys! I'll look into it.
post #5 of 9 (permalink) Old Jul 9th, 01, 01:20 PM
I second js67ss350's comment. I just had the very problem you have described. It appeared suddenly and it was somewhat intermitent. Eventually I caved in and replaced all the plugs. What I found was that it wasn't the plugs, but the number 5 header cooked my MSD plug boot enough to allow arcing at certain RPMs. I replaced the boot and changed the orientation, problem solved.
The lean condition comment is valid, but since this suddenly appeared, the boots/wires are worth taking a look at.
Shawn Peterson
1969 Z28, 406SB
The Green Meanie http://www.geocities.com/corsican69
Shawn is offline
post #6 of 9 (permalink) Old Jul 9th, 01, 08:03 PM
David Pozzi
davidpozzi's Avatar
If it's an exhaust pop, look for an exhaust leak.
Is it a carb backfire?
67 RS 327
post #7 of 9 (permalink) Old Jul 10th, 01, 06:43 AM
If the engine is older...I had a 327 that the one of the cam lobes went bad and caused backfiring throught the carb when I let off the throttle. I pulled the cam and one of the lobes was history. Other than that...timing maybe the problem or fuel mixture.
Toby T. is offline
post #8 of 9 (permalink) Old Jul 11th, 01, 10:31 AM
Most likely, the dwell is off. Make sure your points & condenser are good, then reset the dwell & timing. I had a very similar problem and this took care of it.
[This message has been edited by RW68RSConv (edited 07-11-2001).]
RW68RSConv is offline
post #9 of 9 (permalink) Old Jul 12th, 01, 07:03 AM
Change your spark plugs!
jthomas67 is offline
