Blower motor - Team Camaro Tech
post #1 of 5 (permalink) Old Jun 14th, 00, 01:10 AM Thread Starter
69 Camaro will not blow defroster, air, etc. Could this be from a bad blowermoter in the heater core?
Thank you.
chasd1 is offline
post #2 of 5 (permalink) Old Jun 14th, 00, 02:40 AM
could be, but before replacing the motor , check the fuses and electrical wiring to make sure that you dont have to go through the trouble of replacing the motor only to not have the new one work.
Chris's 67 RS can be seen at http://www.geocities.com/macphreak4evr/index.html
JOIN THE CAMARO NET WEBRING! www.geocities.com/macphreak4evr/webring/webringjoin.htm !!!
Chris Edwards is offline
post #3 of 5 (permalink) Old Jun 14th, 00, 02:56 AM
I would run a length of wire from the hot post on the battery to the terminal on the blower motor. If it works, it's not the motor.
Rons68 is offline
post #4 of 5 (permalink) Old Jun 14th, 00, 10:37 AM
I know they are different, but my 67 had the same problem and it turned out to be a horizontal switch that rests against the air lever in the dash. The switch was dirty and had a groove that didn't allow it to spring out when the lever was moved from the off position.
bonecrusher67conv is offline
post #5 of 5 (permalink) Old Jun 14th, 00, 05:33 PM Thread Starter
Thanks for the suggestions.
chasd1 is offline
