Need to get my 4speed tranny identified - Team Camaro Tech
post #1 of 6 (permalink) Old Jul 9th, 01, 09:26 AM Thread Starter
Well im trying to rebuild it because 4th gear lost 3 teeth and when i call the dealership to get parts they need to know what kind of car the tranny came out of, i have the serial number, it is GM 3846429. Thanks for the help
js67ss350 is offline
post #2 of 6 (permalink) Old Jul 9th, 01, 11:05 AM
The number you gave is for a Muncie 4speed tail housing. Can you get the numbers off of the main case? The dealer will not be able to get you the input, you will have to buy it aftermarket or find someone that has NOS.
secndgn is offline
post #3 of 6 (permalink) Old Jul 9th, 01, 11:10 AM Thread Starter
The number on the gear box is 3925660
-Thanks alot for the help secndgn
post #4 of 6 (permalink) Old Jul 9th, 01, 04:48 PM
JohnZ's Avatar
The 3925660 main case was used from '68-'70 with a 1" countershaft; your tailshaft housing is from a '63-'65 trans, so it's a "mix" of parts. There should be a VIN derivative stamped on the right rear vertical flange of the main case along with a Muncie date code - the VIN derivative will show what it was originally installed in.
JohnZ
'69 Z28 Fathom Green
JohnZ is offline
post #5 of 6 (permalink) Old Jul 9th, 01, 05:07 PM
try year one (www.yearone.com)
badcam is offline
post #6 of 6 (permalink) Old Jul 11th, 01, 04:58 AM
If 4th gear lost 3 teeth it probabily took out the cluster also. If that is the case you are getting to the point that it is not worth rebuilding unless the price of cluster gears has come down since I bought one. It appears to be a basket case so you will have to identify which gear set is in the case. The easiest way is to take it apart and count teeth. Don't go to Chev. to get prices there are some guys on the site that will be cheaper.
oger is offline
