69 Camaro TPI Fuel Tank conversion - Team Camaro Tech
post #1 of 5 (permalink) Old Jul 9th, 01, 07:10 PM Thread Starter
Cool
Has anyone bought or had converted a 69 camaro fuel tank that will allow me to run a 350 TPI motor and have the factory style fuel sender , return, and a high pressure pump in the tank. Looking for a supplier, a service, or any information.
Thanks in advance.
Yellow 69 z28 soon to be 1969 COPO
yellow69z28 is offline
post #2 of 5 (permalink) Old Jul 9th, 01, 07:34 PM
I bought a Rock Valley tank and it is awesome. Not cheap but what is these days. Don't have the number handy but go to www.google.com or prolly a search on this board will get you the contact info.
Good luck!
1969 Camaro RS Convertible
406 SBC Accel Superram, 700R4, 3.55 12 bolt
DSE Modified Wayne Due suspension, 17" Budnik Prisms, Baer 13" 4 wheel discs, Recaro SRD's, Custom Detroit Speed dash
http://communities.msn.com/TheBearHunt/
tples69 is offline
post #3 of 5 (permalink) Old Jul 9th, 01, 07:40 PM
Jody
camcojb's Avatar
It's actually pretty simple to modify your sender for an extra fuel line and use the stock one for a return line. I took some 1/2" tubing, bent to fit the bottom of the tank, drilled a hole (carefully) in the stock sender, and brazed it in. This worked fine until I got my new tank. I was also using an external fuel pump as I didn't know of any internal ones that had enough flow.
Rock Valley makes a nice stainless steel tank with any option including an in-tank pump. These are direct replacements and have a lot better baffling than the stock tanks. I believe the price was $525 or so. I had a #10 outlet and #8 return installed in mine. As I said, they also make one that already has the pump in it like a late-model car. Their phone number is (800) 344-1934.
Jody
camcojb is offline
post #4 of 5 (permalink) Old Jul 10th, 01, 06:09 AM
Bret
Just throwing out options here. A couple years ago one of the magazines featured a black 69 conv. that was running the engine/tranny from a wrecked police package caprice (92-96?). The guy had also swapped in the caprice fuel tank. There was no mention whether it was a direct bolt in or if major modifications were required, but you get a tank mounted fuel pump, the tank is plastic (no rusting) and holds like 23 gallons. Plus you can find them used relatively cheap-search www.car-parts.com
The sedan tank uses a rear fill behind the license plate like a 69 (you don't want one from a wagon-side fill from the quarter panel).
I want to try to run one of these tanks in my 68, I just need to get a chance to take a good look at one and get some measurements.
Bret Copsey
'68 Camaro base coupe
'92 Caprice wagon
'98 Malibu
bretcopsey is offline
post #5 of 5 (permalink) Old Jul 10th, 01, 06:20 AM
Rick
I remember that article. Quite a feat. As I recall, the gas tank required mods to work.
Rick Dorion
69 RS Conv,355,M20,4.10's
RickD is offline
