traction control - Team Camaro Tech
post #1 of 2 (permalink) Old Jan 4th, 01, 02:13 AM Thread Starter
Bruce
do any of you know of or have the optional traction control on their car ? what it is, is a bottle that is mounted in the front of the car, with a hose that runs the length of the car back to the rear wheels with a nozzle on the end that sprays some kind of traction fluid. i thought speed racer was the only car that had something like this. was this common on cars back then ?
i never heard of this option.
later,
bruce
bruce69camaro is offline
post #2 of 2 (permalink) Old Jan 4th, 01, 06:21 AM
The option cosists of two aerosol cans of "Traction compound" mounted in steel cylinders above the back wheels. The aerosol cans look like whipped cream cans with a nozzle on the bottom. The system was vacuum operated from a switch on the dash under the steering column, and when the button was pushed vacuum was supplied to the bottom of the cylinders the cans sat in, and I think the vacuum pulled the cans lower into the cylinder so the traction compound sprayed out onto your wheels, just like when you press on a whipped cream can nozzle. It was available on other cars in 69 besides the Camaro, probably not many people ordered it. Total Camaro production was 118 cars.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
