Can anybody identify this crossram I have? - Team Camaro Tech
post #1 of 5 (permalink) Old Jun 16th, 00, 08:40 AM Thread Starter
Jeff
I just got a crossram which looked like it was a GM piece that had been polished. I knew that it didn't have the casting # and snowflake on either the top or the base. It looks almost exactly like the GM manifold, but no # or snowflake and the top has 2 tabs sticking up in front of the driver's side carb with a hole through each one. The base has a date of 6/14/85 cast into it and the #5893. Did GM ever re-release the crossram manifold without the original # and snowflake or did someone else offer a reproduction of the GM manifold? I'm not sure if I'm going to keep it or just sell it, but it would be perfect for someone doing the vintage racing that is on a budget and can't afford a real #'s matching manifold.
Jeff H - 93 Indy 500 Pace Car, Hugger Orange 69 Z28 with JL8 brakes
Jeff H is offline
post #2 of 5 (permalink) Old Jun 16th, 00, 09:19 AM
Gene
Edelbrock and Offenhauser both made a cross ram intake, although I don't think the piece is in current production.
gheatly is offline
post #3 of 5 (permalink) Old Jun 16th, 00, 09:50 AM
By the number you gave for the base it is an Offenhauser SBC Low Profile Ram Intake Manifold Base. You could get 3 different tops for the base you have. #5901 single,#5903 dual and #5899 3 webbers
Hope this helps
secndgn is offline
post #4 of 5 (permalink) Old Jun 16th, 00, 09:58 AM Thread Starter
Jeff
Do you have any pictures of the Offenhauser base and dual 4 top? The #'s seem to correspond, but I've seen several Offenhauser "crossrams" and none of them look like this or have the water outlet facing forward like the GM unit. And I was gauranteed it was a GM manifold! It was still a great buy and this piece can pass for the GM piece.
Jeff H is offline
post #5 of 5 (permalink) Old Jun 16th, 00, 08:19 PM
David Pozzi
davidpozzi's Avatar
Jeff,
Check your E-Mail I sent you a photo of the offy manifold.
The older I get, the faster I was!
davidpozzi is offline
