need help with carb - Team Camaro Tech
post #1 of 4 (permalink) Old Jan 4th, 01, 03:48 PM Thread Starter
I just rebuilt the 2 bbl rochester on my 70 camaro and now when I try to start the car, gas gushes out of a hole next to the carb opening. I took it off and opened it back up to see if there was anything obviously wrong but I'm not sure what to look for as this is the first time I have attempted to rebuild a carb... Any help or suggestions would be greatly appreciated.
Thanks in advance.
Nick Mitchell
camaroman17 is offline
post #2 of 4 (permalink) Old Jan 4th, 01, 04:26 PM
check your pump in the carb you may have broke it when you put it back together
james is offline
post #3 of 4 (permalink) Old Jan 4th, 01, 04:50 PM
Freddie
Sounds like the float is too high or something is stuck in the needle valve.
'69 RS/SS396 pro street
427/4spd/9"
big gear head is offline
post #4 of 4 (permalink) Old Jan 4th, 01, 04:52 PM
Not sure what you mean by "carb opening" but it sounds like your float may be set to high allowing fuel to enter the carb throat. You don't have to remove the whole carb to make this adjustment so it should be relatively easy to check.
Good luck,
onemorecamaro is offline
