Timing gear or chain - Team Camaro Tech
post #1 of 14 (permalink) Old Jan 4th, 01, 03:50 PM Thread Starter
I'm in the middle of winter prodjects one is changeing the timing chain I'm seriously considering the Danagear drive but havent had any experience with them
80Z28 383 stroker
350 auto 2500 stall
Hollywood Z28 is offline
post #2 of 14 (permalink) Old Jan 4th, 01, 04:59 PM
One word; whirrrrrrrrrrrrrrrrrr. Seriously, gear drives are more accurate but come at the price of noise. They sound cool when one comes through at a cruise but for a daily driver might become a bit annoying. Personal preference item. It's your car.
onemorecamaro is offline
post #3 of 14 (permalink) Old Jan 4th, 01, 05:06 PM Thread Starter
how noisey are they I do drive it daily in the summer months.I've heard they sound like a bad power steering pump is this true
post #4 of 14 (permalink) Old Jan 4th, 01, 05:21 PM
Tony
Hollywood,
They sound like a blower belt/drive pulley whine. It is a medium to high pitch whine not like a power steering pump which groans more than whines (my opinion).
The other thing to consider is that a gear drive does transmitt crankshaft harmonics to the valve train. Which can lead to failure of the weakest parts.
TONY
67 CAMARO R/S CLONE, 355/turbo 350, 200hp NOS,12 bolt,etc...
idoxlr8 is offline
post #5 of 14 (permalink) Old Jan 4th, 01, 05:29 PM Thread Starter
Failuar were in the valvetrain crank or were?Are they that hard on your engine?
post #6 of 14 (permalink) Old Jan 4th, 01, 05:49 PM
Tony
Hollywood,
I ran one in a big block Nova and I have one in my camaro now, It is not a garentee that you will have a failure in the valve train but it is more likely to happen then if you run a chain. My big block ended up breaking the camshaft itself. I have had friends whom have had stock rocker arms fail with only 1000 miles on them and they were new pieces. I am running one in a 355 now and have had it in my last motor, I am running a high dollar valve train (Crane and Lunati pieces) and I check eveything I can as much as possible.
I would not give up the gear drive for another chain in my car though, I like the whine to much and you get alot of looks!!!
TONY
idoxlr8 is offline
post #7 of 14 (permalink) Old Jan 4th, 01, 06:33 PM Thread Starter
I appreciate the advice so far, I'm running crane roller tip rockers and springs, and summit hardened push rods. Whenever doing any type of engine work I don't skimp on my parts. I'd rather get the best now than take a chance.
post #8 of 14 (permalink) Old Jan 6th, 01, 08:01 AM
JohnZ's Avatar
I think you'll be happier with a Cloyes True-Roller timing chain setup - bulletproof, no harmonics transferred to the cam, and no weird noises.
JohnZ
'69 Z28 Fathom Green
JohnZ is offline
post #9 of 14 (permalink) Old Jan 6th, 01, 11:06 AM
Hollywood:
I used to have a Jackson drive on a 355. It
came with a set of offset bushings(which might be helpful) and the attention was a
big ego boost. Loved the noise with a nice cam. I ran summit/comp cam valvetrain on Dart
sportsman heads for at least 30000 HARD miles
without problem. Motor still ran excellent when I sold.
mark mccollum
Mark Mccollum is offline
post #10 of 14 (permalink) Old Jan 6th, 01, 06:17 PM
Wink
I had a Jackson Gear Drive in the engine that I recently replaced. People constantly wondered what was wrong with my motor, then would give me blank, unknowing stares when I'd tell them "gear Drive". It gave me no verifiable performance boost in my street driven car so I went with a double roller chain in the engine that's in it now. I've still got it though...thinkin' about putting it in my Sting Ray.
As an aside...a few years ago, they toured the Jackson factory on one of those TNN gearhead shows. They talked about some wire-wheel deburring process to quiet down the gears. They also sold a "noisy" set for those that prefer that sound. But as I recall they said the only difference between the two was that the noisy ones didn't get deburred. Oddly enough after going through one less machining process, the "noisy" one cost more.
'69 Garnet Red Convertible, Ivory over black, 350 w/turbo 400
POP D TOP is offline
post #11 of 14 (permalink) Old Jan 7th, 01, 04:37 AM
I have a pete jackson in my 68. I thought it was cool when I was 16, now it is a bit annoying. Also I have not had any valve train problems with it. So, if you like the noise, go for it. Just make sure you have a good radio to drown out the noise if you get sick of it.
68RS/SS396 is offline
post #12 of 14 (permalink) Old Jan 9th, 01, 06:46 PM
I also had a Pete Jackson, and I thought it SUCKED. It was to friken loud, half the time I would be turning the radio knob trying to turn it down.
Tuning your engine, forget about it. All you can hear is WWWWWIIIIIINNNNNNEEEEEEE. It was only on my car a week.
I seen in the new Summit cat. that the wet belt is coming down in price. Sorry cant give ya a quote.
CORNHOLIO is offline
post #13 of 14 (permalink) Old Jan 10th, 01, 08:22 AM
I once watched the guys at the IN-n-OUT Burger drive through, fall to the floor when he hit the talk to button to ask for my order. Gear drives are annoying, not to mention a cop magnet. I agree with John-Z, Cloyes Hex-Adjust. Just think, all 302's from Traco Engineering have them, must be worth something.
chacane67 is offline
post #14 of 14 (permalink) Old Jan 10th, 01, 08:54 AM
The "hex adjust" ones are nice, until you run a big cam and the vibration changes the adjustment. I know two people it happened to. My gear drive did not even make it past the engine break in before I changed it, and it was the quite type. My next motor, will be an open belt drive.
1992 Firebird 355/Six Speed (Soon to be LT1)
1991 RS 350 / 700-R4
1987 Toyota Pickup 383 / 500 + HP 10.963 @ 119.95 Slicks / 11.997 @ 114.23 Radials
"Speed KILLS, so drive a FORD and live forever!"
http://personal.lig.bellsouth.net/~racer383/
Mark W. Winning is offline
