steering wheel wobble - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 22nd, 00, 03:22 AM Thread Starter
I have an '87 camaro with a tilt steering wheel that is starting to wobble pretty bad,
both up & down and side-to-side. The actual tilt part still works fine but when it is locked into position, there is still a lot of play in the wheel.
Any ideas on how to tighten it up???
drbean is offline
post #2 of 4 (permalink) Old Apr 22nd, 00, 08:18 AM
You can remove steeringwheel and turn signal assy,and theres 3 0r 4 bolts down in the column youll need a flash light to see them youll need a 1/4 inch socket set and an extension.
DON MAHAN
NVMYSS is offline
post #3 of 4 (permalink) Old Apr 23rd, 00, 06:06 AM Thread Starter
Thumbs up
Thanks Don! I was hoping there was a way to loosen and slide that sleeve down to get at those bolts but I don't know if or how I can. I'm glad to hear that I can get to them by removing the steering wheel.
drbean is offline
post #4 of 4 (permalink) Old Apr 25th, 00, 04:21 PM
I work at a chevrolet dealer in service, we tighten these lower housing bolts all the time, very common on gm colums. good luck
67 RS
355, SUPER T10 4 SPD
9" FORD
67FREAK is offline
