Speedometer Cable Reducer/Adapter - Team Camaro Tech
post #1 of 2 (permalink) Old Dec 18th, 00, 12:01 PM Thread Starter
BUD
While looking at the 69 AIM manual I see where an adapter & key are called for when a speedometer cable is hooked up to 4-speed when positraction is used. Why is this? The adapter I bought in a group of parts is geared 1 to 1 , so it is not always for gearing reduction for certain rear end gears. Is there a difference between cable adapter and gear reducer? Any thoughts appreciated. What do most of you use to lubricate cable in housing? Thanks
BUD is offline
post #2 of 2 (permalink) Old Dec 19th, 00, 09:25 AM
year one sells reducers based on your gear / rear ratio and trans type+tire size. ground up also carries the same thing. give them a call and they can tell you what gear reducer to get so your spedo is correct.
groundup = 18663582277
year one = 1-800-Year-One
Chris's 67 RS can be seen at http://www.67rs.com
JOIN THE CAMARO NET WEBRING!
Chris Edwards is offline
