67 A/C - Team Camaro Tech
post #1 of 5 (permalink) Old Mar 12th, 00, 08:56 AM Thread Starter
My 67's A/C unit has been removed over the years by less than qualified mechanics. I have most of the parts but I need a good tech book that covers the install/repair of 67 camaros A/C units. Any help out there. My car came with factory A/C.
captbluetiger is offline
post #2 of 5 (permalink) Old Mar 12th, 00, 06:33 PM
Cool
Get the 67 assembly manual. Bought mine from Paddock's awhile back.
67 SS
70 Z/28
camaroguy is offline
post #3 of 5 (permalink) Old Mar 17th, 00, 02:51 PM Thread Starter
Will it explain the vacumm hoses and how the system works?
post #4 of 5 (permalink) Old Mar 17th, 00, 07:14 PM
As for '67 A/C, the assembly manual is definitely your best bet. All vacuum line and wiring schematics are shown. Of note, the '67 A/C system suffered from too much reliance upon a vacuum switch at the A/C / heater control panel. This thing apparently required constant replacement of a plastic cap which, in turn, required removal of a whole bunch of other stuff (you know what I mean). I chose to install the '68 version factory A/C system in my '67 following the assembly manual for that year for A/C only. The vacuum and A/C electrical systems seem to be a little more refined a'la '68. The wiring harness repro's for '68 cars include the ambient switch circuit and a couple of other quirks that can either be ignored or made to disappear (relay on top of evaporator box is different, etc.). One word of warning on '67-'68 a/c...remember how impossible a clean replacement of the blower motor is without the right fender being gone? Same thing is more or less true of the vacuum tank under the left fender. Get a good one and test it! Same for plenum valve and right side kick panel vacuum pots. Ain't this fun?
JFord is offline
post #5 of 5 (permalink) Old Mar 21st, 00, 05:27 PM Thread Starter
Cool
Thanks John what you wrote will come in helpfull. I will go ahead and change over to a 68 A/C that little vacuum switch my be the main cause of this cars A/C's demise back in the 70's that started my nightmare. I'll check those plenums. I believe the fun has just began...
