Stripped bolt on Tranny - Team Camaro Tech
post #1 of 5 (permalink) Old Jan 31st, 01, 01:00 PM Thread Starter
Angry
I changed the fluid and filter recently on my 400 turbo and while torqueing down the bolts I stripped one that holds my shifter linkage. There has not been a problem with it but I am looking for the best way to fix it. Help me fix my problem!
73' Camaro with 94' LT1 and 400 Turbo
gadzooks25 is offline
post #2 of 5 (permalink) Old Jan 31st, 01, 01:31 PM
I did the same thing last year on my TH-350.
This winter I pulled the tranny and removed the tranny pan. I inspected the mounting holes and noticed that it wasn't just the shifter bracket threads. Several holes had threads that were not good. I decided to repair all the holes. I bought a heli-coil thread repair kit at NAPA. Drilled out the holes, didn't tap all the way through and inserted new threads. Everything tightened up great this time.
rodsters is offline
post #3 of 5 (permalink) Old Jan 31st, 01, 02:47 PM
same as above, heli coil, could certainly bo done on your back. no need to remove unit.
G'luck
PS. Great site
68ragtop is offline
post #4 of 5 (permalink) Old Jan 31st, 01, 03:38 PM
A better choice over the heli-coil is a Timesert, I think that what it's called. The heli-coil is like a spring and evenutally breaks. The Timesert is a solid tube that is threaded in the inside and outside. The kit is hard to find, but if you have to remove the bolt every now and then, it's worth it.
Allen M is offline
post #5 of 5 (permalink) Old Jan 31st, 01, 04:27 PM
After using the heli-coil I would agree that it could be done from underneath. I pulled my tranny and engine to detail the engine compartment and do some engine work.
rodsters is offline
