bolt check! - Team Camaro Tech
post #1 of 18 (permalink) Old Jan 31st, 01, 07:12 PM Thread Starter
a large bolt fell out of my car (uh oh) and I can't figure out where it goes. it's making me crazy cuz it's a really big bolt. it's 5 inches long with thread on the last inch. anyone got any places I shouold check for missing bolts?
lil_beast_67 is offline
post #2 of 18 (permalink) Old Jan 31st, 01, 07:17 PM
Check you motor mounts and lower a-arms. Maybe starter bolt?
68 RS red w/ white stripes
67 SS/RS restoring
camaroguy is offline
post #3 of 18 (permalink) Old Jan 31st, 01, 07:50 PM
Come on!! what size?
3/8,7/16,1/2 ?would help a lot ,to help you!
Joni
joni is offline
post #4 of 18 (permalink) Old Jan 31st, 01, 08:19 PM Thread Starter
oops, forgot that entirely. shaft is 3/8 bolt head is 5/8. I'm beginning to think lower A-arm. I'll have to check tomorrow though, it's a little late. thanks for the quick replies guys.
post #5 of 18 (permalink) Old Jan 31st, 01, 09:03 PM
Sounds like it could be a subframe bolt
67 Camaro Conv w/ supercharged 350
David R is offline
post #6 of 18 (permalink) Old Jan 31st, 01, 09:06 PM
SOUNDS LIKE A HEAD BOLT TO ME BEING A 5/8 HEAD ON IT ,MAYBE LEFT OUT FROM RECENT HEAD WORK?
NORM
67 SS
67az.ss is offline
post #7 of 18 (permalink) Old Feb 1st, 01, 02:25 AM
Head bolts don't fall out, unless there was no gravity, (or it was left out of the car following some work) and all of the long ones are under the valve covers, so unless you have a hole in the top of your valve cover it didn't come off your engine.
You have a choice of starter bolts, (not 5/8"), subframe bolts (also not 5/8" head and not 5" long), lower control arm bolts, (might be 5/8" been a while since I fooled with them), motor mount pivot bolts (think these are 9/16" head), alternator pivot bolt (at least on a 69 style moount but this is a 9/16" head bolt), maybe a rear spring front bushing bolt (but theres no way for this to fall out in one piece)
Those are all the long bolts I can think of on a Camaro. I'd bet it's the starter bolt though.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
[This message has been edited by Mark C (edited 02-01-2001).]
Mark C is offline
post #8 of 18 (permalink) Old Feb 1st, 01, 03:12 AM
Rick
What side did it fall out on?
RickD is offline
post #9 of 18 (permalink) Old Feb 1st, 01, 04:07 AM
I recently changed a thermostat in my 67. One of the bolts holding the water head was approx. 3 inches long. I was amazed when I saw this myself. Try checking there.
Gambler is offline
post #10 of 18 (permalink) Old Feb 1st, 01, 04:15 AM
I've been helping KZ convert his '69 to power steering, and that sounds close to the size of the bolts that hold the steering box against the subframe. Good luck finding its home!
No 'E' in Camaro is offline
post #11 of 18 (permalink) Old Feb 1st, 01, 04:17 AM Thread Starter
heading to school now in my other car, I'll check when I get home. I think it's the lower A-arm because I just installed dropped spindles and disc brakes and it's a new bolt. It could be the starter bolt, but i don't think so, because it was really clean and I went through a really bad oil leak that sprayed most of the engine. I'll have to check that after teh a-arm. thanks for the quick replies guys.
post #12 of 18 (permalink) Old Feb 1st, 01, 05:10 AM
DjD
DjD's Avatar
Wow! I wish I could be posting from my car!!! LOL!!!
...Dennis
The Cars:
'69 RS Convertible w/SS trim
'96 Z28SS #1679 of 2410
The Club:
Camaros Limited Nor-Cal
DjD is offline
post #13 of 18 (permalink) Old Feb 1st, 01, 07:05 AM
could it be the Balancer bolt? there about 4" long and pretty thick...
Chris's 67 RS can be seen at http://www.67rs.com
JOIN THE CAMARO NET WEBRING!
Chris Edwards is offline
post #14 of 18 (permalink) Old Feb 1st, 01, 07:44 AM
I'd bet it's the starter too.
JD
John Doyle is offline
post #15 of 18 (permalink) Old Feb 1st, 01, 08:41 AM
Jeff
Lightbulb
on your recent install check to see if you used the new bolts or if you have new ones with a old one in place. you might have used an old one and left the new one on the rails somewhere and if finally fell off. good luck in finding the plae it goes to
Jeff
HawaiianCamaro is offline
