spark plugs - Team Camaro Tech
post #1 of 2 (permalink) Old Aug 11th, 00, 07:33 PM Thread Starter
What are the differences among the following spark plugs?
AC-45S
AC-44
AC-44S
Can they be interchanged (as a set) without damaging the engine?
Thanks.
cturner is offline
post #2 of 2 (permalink) Old Aug 12th, 00, 09:17 AM
In AC the S means extended tip. The number signifies the heat range. Lower number is colder plug for hotter engine. For instance a 327/275 should run a 45S with standard compression ratio. You can try colder or hotter but then you'll have to check them after a few miles to see what color the porcelin around the electrode is. They should be a light brown kind of like bran flakes. If they are lighter than that go one range colder which is one number lower. If darker then go one number higher. You should always run a complete set of the same plugs. You'd hate to have one cylinder colder and fouling and another so hot that it goes off too soon.
mcpc is offline
