327 OR 350 - Team Camaro Tech
post #1 of 11 (permalink) Old Apr 5th, 01, 07:08 PM Thread Starter
I have a 1981 Camaro currently equiped with a 305, however I am going to change the motor soon and I need some advice, I have a compleate 350 block its either a 72 or 73 with 2 bolt mains, the block is quite usable however requires machining, But on the other hand I have a 327 crank that I have had machined and I Have new bearings for it, Im just currious on Which you would recomend the 327 or the 350, I am running a TH 350 with a 3:40 posi rear, I am considering upgrading to a TH 700 and 4:00 or so ratio in the near future soon, Im curious if my block will work with a 327 crank, I already have 202 heads for the engine and an Aluminium intake of of an early camaro. How much differance in drivability is there from a 327 to a 350 I know that the 327 typicaly revs higher and the 350 would produce the most low end torque but Im not sure what to do any comments or sudjestions would be appreciated.
mbonazzo is offline
post #2 of 11 (permalink) Old Apr 5th, 01, 07:11 PM Thread Starter
Also I forgot to mention this car will be used as an ocasional driver with some drag race duty, however the drags are just for fun for me I dont really care what it turns. I just need some advice thats all.
mbonazzo is offline
post #3 of 11 (permalink) Old Apr 6th, 01, 05:28 AM
If you already have most of the parts I would say go for the 327. They are pretty fun. If you have the cash though the 350 will give you more torque to move the car. However, if it is mainly a drag car and you are going to be using 4 something gears and a loose (high stall) torque converter than it won't really matter too much because you will already be higher up in the powerband. Like you already said, the 327 can rev up more quickly, the 350 has a bit more in low-mid rpm torque, it is really your call. If you want to drive it on the street the 350 will idle better with the same cam too.
boodlefoof is offline
post #4 of 11 (permalink) Old Apr 6th, 01, 07:51 AM
I love the 327, good engine, durable and cheap to build up, but so is the 350, like the previous post stated, the 350 has more midrange, but you can make a 327 bad to the bone also.
or just build the 350 and tell them its a 327, most people wont be able to tell since the blocks are the exact same size.
Chris's 67 RS can be seen at http://www.67rs.com
JOIN THE CAMARO NET WEBRING!
Chris Edwards is offline
post #5 of 11 (permalink) Old Apr 6th, 01, 07:39 PM Thread Starter
Thanks that has been some help, I think Im going to with the 327 just cause the 81's never came with one and I like to be differnt. but what pistons should I run? what compression ratio? Also is the crank a drop in affair or will any machine work to the block have to be done?
mbonazzo is offline
post #6 of 11 (permalink) Old Apr 7th, 01, 05:40 AM
crank should drop right in with the correct sized bearings if it has been machined down. Compression ratio has a lot of factors including cylinder heads (both type and efficiency of combustion), camshaft (some cams will bleed off compression due to overlapping times of the valve being open), and the type of gas you plan on running.
post #7 of 11 (permalink) Old Apr 7th, 01, 06:13 AM
Hey, find the casting number on your crank and go to www.mortec.com and go to crank casting numbers and look it up, u mite be lucky and have a 327 large journal crank witch will drop rite in a 350 block, if its not no biggey just get the special bearings,
as far as compression dont go over 11 to 1
but stay over 9 to 1.....
poundinpopeye is offline
post #8 of 11 (permalink) Old Apr 7th, 01, 07:25 PM Thread Starter
Thanks Ill check out that casting number, I am planning on running premium gas bout 93 or so octane I have a set of 202 heads, this car will be street driven a lot though. any recomendations. Im not planning on running a nutso cam, just enough to give it a bit of a rough idle
mbonazzo is offline
post #9 of 11 (permalink) Old Apr 9th, 01, 02:31 AM
Another reason to go 327? Most TH 700 do not handle torque well. Your smaller 327 will work well with that tranny and it will last longer in the process. That 3.06 first gear will negate the need for the extra torque of the 350. That tranny and 4.xx gears will surely provide tire spin, why more torque? Nice choice!
I know because my 4L60 had to be "radically beefed" to sit behind my 358...
MLRTYME Racing Enterprises
MLRTYME is offline
post #10 of 11 (permalink) Old Apr 12th, 01, 01:21 PM
Thumbs up
It's really your call because a 350 and a 327 are both the exact same block the only difference is the cylinder bore is obviously bigger on the 350. So anything will swap from either one to the other.
1968camaro123 is offline
post #11 of 11 (permalink) Old Apr 12th, 01, 02:34 PM
The cylinder bore is the same at 4.00'', the difference is in the crankshaft stroke at either 3.25'' for the 327 or 3.48'' for the 350.
