Wipers not stopping - Team Camaro Tech
post #1 of 8 (permalink) Old May 19th, 01, 04:40 PM Thread Starter
Unhappy
My wipers go up and down through the whole range of wiping but when I shut them off the don't rest at the bottom. They go part way up maybe 6 inches. Its irratating and blocks my view. Anyone else have this problem?
2nd can I make my wipers speed change like modern cars with intermitten wiping. Is it the switch or the motor that I have to change?
Tony
obnoxious 67 camaro under construction. TH350/383 stroker w/ aluminum Edlebroc RPM heads,cam, and carb.
OBNXUS67 is offline
post #2 of 8 (permalink) Old May 19th, 01, 09:06 PM
You can get a intermittant wiper setup thru JCWhitneys. Napa even used to sell them but I dont know if they still do or not. As far as the wipers not stopping in the right place, there is a switch inside the motor assembly that is supposed to stop the wipers at the bottom...I dont know if there is any adjustment in there or not though.
375hp 78 Chevy truck
77 Chevy Nova
95 Chevy Lumina 3.4L
and building a 78 Nova
travis is offline
post #3 of 8 (permalink) Old May 22nd, 01, 04:54 PM
Gary
This may sound simple, don't drive it in the rain . The only time my 69 sees water is when I wash it.
Gary Dorion is offline
post #4 of 8 (permalink) Old May 23rd, 01, 04:13 AM
JohnZ's Avatar
You need a new or rebuilt wiper motor; the park function is controlled by a series of switches and cams inside the motor gearbox.
JohnZ
'69 Z28 Fathom Green
JohnZ is offline
post #5 of 8 (permalink) Old May 23rd, 01, 05:45 AM
Have you recently changed the wiper motor or has it always done this? When I changed the wiper motor on my 69, I didn't have the wipers all the way in the park position, so when I bolted the wiper mechanism to the motor, it recognized the park position(due to the switching in the motor) as half way up. I had to unbolt the motor and reposition my wipers, put it all back together and it worked fine.
Dean
bilydean is offline
post #6 of 8 (permalink) Old May 23rd, 01, 06:55 AM
Mine have a similar problem. They stop wherever they are when I turn off the wipers. They don't return to their resting position when turned off. The only way to get them down is to turn them off when they are at the end of their down sweep.
1970 mostly original
307,TH350
F41
bowtie-70 is offline
post #7 of 8 (permalink) Old May 23rd, 01, 09:39 AM
Thumbs up
hello guys i had the same problem. a friend suggested checking my ground on the on off switch. after removing and cleaning the grounding plate under the switch and end terminal my problem was solved. may be worth a try
69 z28
trezpan is offline
post #8 of 8 (permalink) Old May 24th, 01, 03:49 AM
I don't know about the 67's, but my 68 motor didn't work, so I drilled out the crimps (as directed in the service manual)and repaired a broken wire. Also had to do some work on the park cam and contact (the copper contact arm had bent). On my motor there are 2 marks on the housing 90 deg apart, and there is a mark on the arm that connects to the oscillating arms driving the wipers. These marks must be lined up properly. When I first put it back together, my wipers stopped in the middle of the window. I checked and found that I had misalligned the arm by 90 degrees. Don't know if this is your problem, but I would check it before buying a motor.
H-dog
[This message has been edited by H-dog (edited 05-24-2001).]
H-dog is offline
