vacuum pump - Team Camaro Tech
post #1 of 12 (permalink) Old Apr 6th, 01, 01:14 PM Thread Starter
Anyone have an idea on where I can get a 12V vacuum pump to run my hideaway headlights? My cam has a lot of overlap so my engine vacuum is pretty low, in the 8" range.
thanks
Dean
bilydean is offline
post #2 of 12 (permalink) Old Apr 7th, 01, 05:40 PM
99 and up ford F super duty diesels use a 12 volt vacume pump.Its a very small unit thats used for vacume to heater controls & vacume lock out hubs. Hope this helps.
gene stills is offline
post #3 of 12 (permalink) Old Apr 8th, 01, 08:51 AM
JohnZ's Avatar
GM also used them on some cars in the 80's - try an Olds or Cadillac dealer. Also, I believe MasterPower Brakes (North Carolina?)carries them - about $300.
JohnZ
'69 Z28 Fathom Green
JohnZ is offline
post #4 of 12 (permalink) Old Apr 9th, 01, 05:20 AM
I noticed that the post:
https://www.camaros.net/forum/Forum7/HTML/001168.html
from the brakes & suspension section mentions a GM pn for a vacuum booster
ibjoe is offline
post #5 of 12 (permalink) Old Apr 9th, 01, 05:59 AM Thread Starter
Thanks guys for all the info. I will certainly be checking out the various applications as well as that GM number. Man this is a great site.
Dean
bilydean is offline
post #6 of 12 (permalink) Old Apr 10th, 01, 05:35 AM
frank
The older Volvos ( 73-76) used a vacuum booster. Nice compact unit and very efficient.
frankk is offline
post #7 of 12 (permalink) Old Apr 10th, 01, 07:44 AM Thread Starter
Thanks Frank, I will check that option also.
Dean
bilydean is offline
post #8 of 12 (permalink) Old Apr 11th, 01, 09:08 PM
Try AcDelco PN 215-119 at your GM dealer.
I think it's the same one Master Brakes sells for $300 or so. I got mine for $200 from GM. The weather pack connector was about $20 also. I use it for my power brakes, works great!
I believe this is off an 82 Chevy Cavilier. So you might find one cheeper at a bone yard.
[This message has been edited by mellow-yellow (edited 04-12-2001).]
mellow-yellow is offline
post #9 of 12 (permalink) Old Apr 12th, 01, 05:37 AM Thread Starter
Talking
Mellow-Yellow, I will tinkering on my car this weekend and will call around for that part as well. Thanks for the suggestion.
Dean
bilydean is offline
post #10 of 12 (permalink) Old Apr 18th, 01, 11:44 PM
Just wondering...Does a vacuum pump have any advantages over a less expensive (around 40 bucks) vacuum reserve cannister?
my69gofast is offline
post #11 of 12 (permalink) Old Apr 19th, 01, 04:11 AM
Jody
camcojb's Avatar
The advantage of the pump is that it makes it's own vacuum (20 inches or so). A canister will store some extra vacuum but it'll still be low if that's what your engine makes (big cam, etc.).
Jody
camcojb is offline
post #12 of 12 (permalink) Old Apr 19th, 01, 10:49 AM Thread Starter
Well I fixed my problem w/o getting the vacuum pump. Turns out, as has been said numerous times on this site, the vacuum lines were backwards, even though the installed correctly per the markings on the vacuum relay. However, the reason I was asking about the vacuum pump was the covers wouldn't open. I took the vacuum relay off and found the seal in the relay had a portion of the lip seal turned, which would constantly bleed off the vacuum. With that corrected(and the hoses hooked up correctly) my 8" of vacuum magically open up the doors. Thanks for all the help.
bilydean is offline
