STRANGE ENGINE OIL LEAK - Team Camaro Tech
post #1 of 5 (permalink) Old Jul 30th, 01, 05:27 PM Thread Starter
Unhappy
I just started my 327 in a 68RS camaro and there is a nasty oil leak between the head and block by the last lower head bolt at #7 cylinder side. Where could the oil be coming from??? The block was decked and the heads are new. This is a big let down after working 3 plus years at this ground up restoration only to fire up the engine and encounter this. Does anyone have any thoughts before I tear it down?
Dan Chilla
68RS 327 stroked to 389
Dan Chilla is offline
post #2 of 5 (permalink) Old Jul 30th, 01, 05:44 PM
Sounds more like a valve cover gasket. It might be curled under a bit when the cover was installed.
68 SS 396
camaroguy is offline
post #3 of 5 (permalink) Old Jul 30th, 01, 09:23 PM
Your oil leak could be coming from the rear corner of the intake manifold, or the oil pressure sender (gauge line fitting).
Also there is a oil galley that takes a plug on the deck just down from the galley that the oil pressure fitting goes into, the cylinder head covers half of it, if the plug was missing oil would spray out but it could be loose, usualy that plug is never removed but ya never know, the first place to look is the oil pressure fitting
1968DON is offline
post #4 of 5 (permalink) Old Aug 1st, 01, 03:43 AM
Hey guys, what about that plug you put under the head in the back. I believe it is a port left over from casting. If the plug was forgotten, you would have a nasty leak.
1992 Firebird 355/Six Speed
1991 RS 350 / 700-R4
1987 Toyota Pickup 383 / 500 + HP 10.79 @ 123.95 Slicks / 11.997 @ 114.23 Radials
"Speed KILLS, so drive a FORD and live forever!"
http://personal.lig.bellsouth.net/~racer383/
Member of the "unwanted" 3rd Gen group.
Mark W. Winning is offline
post #5 of 5 (permalink) Old Aug 1st, 01, 11:01 AM
David Pozzi
davidpozzi's Avatar
I have a leak on that plug too. I believe the way engine blocks are cleaned these days, by putting them in an oven, cooked out the sealer on this plug and allows it to leak.
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
davidpozzi is offline
