car wont start after spark plugs changed - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 6th, 01, 03:22 PM Thread Starter
Angry
ia have a 94 z28 5.7l 350 i changed the spark plugs because the car was acting sluggish and when i was finished replacing them the car wouldnt start back up i did the spark test "plenty of spark" so what could it be it would start right up but after the spark plug change it just keeps cranking but will not start. thank you any thoughts would be very greatful
post #2 of 5 (permalink) Old Apr 6th, 01, 03:43 PM
did you check the wiring going to the fuel injectors.check to see if fuel is reaching fuel rail.probally just loose connection some where but you said the car was sluggish befor.i had a 91 s-10 that did that and two days later the fuel pump went out.hope this helps......Luke
Lukes67 is offline
post #3 of 5 (permalink) Old Apr 6th, 01, 03:43 PM
Not to be a smart#$2, but recheck the wires for correct position, and if that is not the problem make sure the plug wires are securely fit on the plugs. Those late model Camaro's are a tight fit and it is hard to get the wires on correctly.
jamesbern is offline
post #4 of 5 (permalink) Old Apr 6th, 01, 05:32 PM
Charley
clill's Avatar
Is it possible that you put too long of a plug in ? Could the piston have hit the plug and closed the Gap ?
clill is offline
post #5 of 5 (permalink) Old Apr 6th, 01, 07:13 PM
David Pozzi
davidpozzi's Avatar
chill,
Your'e readin' my mind!
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
davidpozzi is offline
