Hyd Clutch linkage problem - Team Camaro Tech
post #1 of 4 (permalink) Old May 20th, 01, 12:23 PM Thread Starter
Marty
Guys, I've got a T5 in my 69 with a hydraulic clutch setup. Broke the linkage that goes from the clutch pedal to the piston in the master cylinder that is attached to the firewall. Does anyone know whether this means a new master cylinder or can the rod that goes into it be replaced? The rod broke and is now bent about 30 degrees. Was a bitch trying to get it home - used a socket to "align" the two and kept pressure on the clutch the whole way home.
Marty
69 Camaro, 350, TrickFlow heads, T5, 3.73
69CamaroSS is offline
post #2 of 4 (permalink) Old May 20th, 01, 03:03 PM
Bill
Marty,
It probably depends on the manufacturer of the master cylinder. I would give them a call and find out if the rod is available.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
1973 Z-28 ..one family car...Brother bought it new in 73
BillK is offline
post #3 of 4 (permalink) Old May 20th, 01, 05:12 PM Thread Starter
Marty
I would assume that the manufacturer is BorgWarner since it's attached to the T5. I didn't install the trans, it was there when I bought the car but I assume that it is out of a 3rd gen Camaro.
I got the rod straighted, but it doesn't seem to screw in - seems to be mounted in a swivel as it can rotate and pivot at the firewall. Would JB Weld work on something like this? I'm also thinking of threading the remaining rod and putting a rod coupling on it.
post #4 of 4 (permalink) Old May 22nd, 01, 04:27 PM Thread Starter
Marty
Anybody else have any advise on this subject?
