10 bolt rear help? - Team Camaro Tech
post #1 of 14 (permalink) Old May 20th, 01, 03:33 PM Thread Starter
i now have a 10 bolt in the rear of my 69 camaro. i am not sure if its the origional rearend or not! how do i identify if its an 8.5 or 8.2 carrier. is there a way to do this without taking it apart? i would like to put a auburn limited slip in it and change the gears to about 3:55 or so. i would like to buy the parts and then when i have them all start working on it. i cant have the car down for an extended amount of time because i drive it every day to work.
vtec is offline
post #2 of 14 (permalink) Old May 20th, 01, 03:43 PM
if I'm not mistaken, first gen camaros never came with a 8.5 inch 10bolt. Only 2nd gen or later. I'm not positive tho.
68 396 ragtop is offline
post #3 of 14 (permalink) Old May 20th, 01, 03:54 PM
Yes, you can make the assumption it's an 8.2.
The 8.2 was used in the 1970 10 bolt as well. In 1971 the corparate rear end debuted, which was a 8.5" ring gear.
The center section of your rear should have the casting # of 3894859NF.
NastyZ is offline
post #4 of 14 (permalink) Old May 20th, 01, 04:39 PM
last spring, i took the 8.2 out of my 71 nova and put in a 8.5 out of a 73 nova..made sure to note external differences. what i noticed was that the 8.5 had "ears" on the bottom of the centersection that were parallel to the ground..the 8.2 just had rounded corners. just look under the car from the rear, and if it is flat on the bottom, it is an 8.5. i checked other cars at local boneyard-french lake auto parts( www.frenchlakeautoparts.com ),and all the newer 8.5 equipped vehicles back this find up.hope this helps..
[This message has been edited by novaderrik (edited 05-20-2001).]
novaderrik is offline
post #5 of 14 (permalink) Old May 20th, 01, 04:43 PM
Be careful assuming it's an 8.2" just because that's stock for your car...after 30+ years, you never know what someone might have swapped in. Just one more possible telltale sign...the 8.2" 10 bolts had an upside down "V" stamped into the cover to assist with oil distribution. It's pretty distinctive, so you should be able to tell...
1976 Type LT Restification (in progress)
1968 2 door sport coupe...wife's car!
The Monday Nite Car Club! (New site)
76Maro is offline
post #6 of 14 (permalink) Old May 20th, 01, 04:46 PM
The 8.5 does have the ears on it and also the cover has a distinct bulge running vertically on it. Also check the numbers located on the passenger side axle tube.
tdks is offline
post #7 of 14 (permalink) Old May 20th, 01, 07:50 PM Thread Starter
Red face
i havent had time to check it out yet but lets assume its a 8.2, who makes a limmited slip for it? everywhere i look things are for the 8.5 or 12 bolts.
vtec is offline
post #8 of 14 (permalink) Old May 21st, 01, 05:18 AM
Vtec,
If you go to www.noveresource.com they have a good description of the differences between an 8.2 and 8.5. Check the "axle" section.
kknapp433 is offline
post #9 of 14 (permalink) Old May 21st, 01, 05:20 AM
post #10 of 14 (permalink) Old May 21st, 01, 05:28 AM
joseph l clance
joe clance's Avatar
<BLOCKQUOTE>quote:</font><HR>Originally posted by vtec:
[Bassume its a 8.2, who makes a limmited slip for it? .[/B]<HR></BLOCKQUOTE>
Auburn gear is currently the on co. that makes an 8.2 for 3:08 and &gt;.. recently replaced my 3:08 with 3:55 richmond gear, and Auburn Gear posi differential. Initailly it worked great ( W/ std gear oil and posi lube) for about 1 month ( got noisey when cornering). Then replaced the gear oil w/ red line Synthetic gear lube w/ one bottle of posi (gm) posi lube). Runs great and no more noise @ &gt; 3mos.
joe clance is offline
post #11 of 14 (permalink) Old May 21st, 01, 09:16 AM
Joe Clance,
I have 2.73 gears. I guess that means I have a 2 series carrier. Does anyone make 3.55 gears for this? Can I put a 3 series carrier in?
post #12 of 14 (permalink) Old May 21st, 01, 12:03 PM
joseph l clance
joe clance's Avatar
<BLOCKQUOTE>quote:</font><HR>Originally posted by kknapp433:
Joe Clance,
<HR></BLOCKQUOTE>
As long as the intended gear used is 3:08 or greater, you should be fine w/ series 3. Check w/ auburn beFore purchasing, they cost in the neighborhood of $300.00 and the richmond 3:55 gear set is approx $200.00.
post #13 of 14 (permalink) Old May 21st, 01, 01:43 PM Thread Starter
knapp,
thanx for all the help, i found that my rear was made in 1967,is an 8.2 and has 3.08 open gears. now i know what i have and what i need to get. again thanx a million! vtec
vtec is offline
post #14 of 14 (permalink) Old May 21st, 01, 04:34 PM
Freddie
I can get you a US Gear Torq Line posi for the 8.2. It is a copy of the original Eaton posi used by GM. It is a better unit than the Auburn. Cost is $350 plus shipping. Do you have any experience setting up a ring & pinion? Do you know how to set the pinion depth, backlash, bearing preload and read a contact patern? If you don't then you probably need to find someone who does, otherwise you may trash the new gears.
'69 RS/SS396 pro street
427/4spd/9"
big gear head is offline
