Valve Covers? - Team Camaro Tech
post #1 of 7 (permalink) Old Jul 31st, 01, 04:20 AM Thread Starter
Cool
Hi Guys, been a while. First things first. College football begins in less than a month. CANT WAIT! Does anyone know where I can get a set of chrome valve covers for a 67 with a 327/275? The set I have currently does not have any holes in them. I guess these "holes" are for pcv valves? I did find a set at Classis but just the valve covers themselves as $140. OUCH! Any help would be appreciated.
Gambler is offline
post #2 of 7 (permalink) Old Jul 31st, 01, 04:33 AM
The 67 valve covers do not have any PCV holes. If your car has the correct block you have the right covers. Take a look at the left front pedistal and take a look at the code. It should read something like:
T0321MK The block should end with MK, ML, MM, MN for a 327/275 horse.
~ mark
markZ11 is offline
post #3 of 7 (permalink) Old Jul 31st, 01, 07:03 AM
DjD
DjD's Avatar
I agree with Mark. There should be a vent (draft tube at the back of the block that runs to the air cleaner. You may have a PCV screwed into the base of the carb or on the breather tube on the front of the intake manifold.
...Dennis
'69 RS Convertible w/SS trim
'96 Z28SS #1679 of 2410
"The Club"
DjD is offline
post #4 of 7 (permalink) Old Jul 31st, 01, 02:17 PM
My 67 -350 has the chrome covers with no holes. I do have a PCV valve in a large vacuum hose which goes from the front of the Rochester Quadrajet to the vacuum port in front of the distributor. Good Luck
jimbarbh is offline
post #5 of 7 (permalink) Old Jul 31st, 01, 06:05 PM
i have a set of original 327 valve covers, actually my dad has them, we could probably sell them, but not for cheap.
chevybuilder67 is offline
post #6 of 7 (permalink) Old Aug 1st, 01, 09:39 AM
Talking
If you need to hook up a pcv and want to keep your valve covers, why not drill a 1 3/16 hole in the proper place (where it does not hit the valve train) and use a baffled grommet? The baffled grommet is available from most any speed shop for about $5.
68 convertible
ccpeat is offline
post #7 of 7 (permalink) Old Aug 2nd, 01, 03:09 PM
Don't '67 and earlier blocks have the large oil filler/vent tube at the FRONT of the block?
'69 Garnet Red Convertible, Ivory over black, 350 w/turbo 400
POP D TOP is offline
