Rag joint - Team Camaro Tech
post #1 of 11 (permalink) Old May 21st, 01, 03:16 AM Thread Starter
I noticed my manual steering's Rag JOint is
pretty well trashed. The Repair maual says
to remove the steering box is there an easier
way?
Dave69Z is offline
post #2 of 11 (permalink) Old May 21st, 01, 03:46 AM
No easier way. But, you don't have to completely remove the steering box. Just remove all but one bolt and loosen the remaining bolt so the box will rotate. Disconnect the pitman arm linkage. Take the nuts off the rag joint and you should be able to rotate the steering box enough to get the rag joint out. This is a fairly easy job on manual steering.
George Thomas
1969 Camaro Z28 X77
[email protected]
http://home.cox.rr.com/gthomas/gt.htm
GeorgeZ28 is offline
post #3 of 11 (permalink) Old May 21st, 01, 08:49 PM
I always attack it from the other end...loosen the bolts under the dash that hold the steering column in place (you may have to remove them) and you will have just enough slack to do the job. I have never done it on a camaro but have done it on a dozen other various chevys and fords and it works for me...and I think it would be a lot easier too.
375hp 78 Chevy truck
77 Chevy Nova
95 Chevy Lumina 3.4L
and building a 78 Nova
travis is offline
post #4 of 11 (permalink) Old May 22nd, 01, 03:32 AM
Stupid Q (Sorry):
What does the rag joint look like and what does it do???
Thanks!
RFrenette is offline
post #5 of 11 (permalink) Old May 22nd, 01, 04:10 AM
Rick
I've done it both ways. It's much easier to loosen the steering column and get some play. The rag joint has to slip off the splined steering shaft end. It will make a nice improvement.
RickD is offline
post #6 of 11 (permalink) Old May 22nd, 01, 10:28 AM
The "rag joint" joins the steering column to the steering box. Primarily its purpose is to dampen vibration/shock between the steering system and suspension, and the steering wheel. Without this dampener you'd feel a lot more vibration/jolts from a less than smooth road surface. Probably you'd end up cracking some plastic dash parts too. Also, it makes it easier to join the steering column to the steering box when the alignment isn't perfect.
George Thomas
1969 Camaro Z28 X77
[email protected]
post #7 of 11 (permalink) Old May 22nd, 01, 03:19 PM
Jonesy's Avatar
Jonesy is offline
post #8 of 11 (permalink) Old May 23rd, 01, 01:42 AM
Wink
Ahhh... Thanks!
So, in order to remove the steering col, I have to unbolt this.
Got it.. Thanks!
post #9 of 11 (permalink) Old May 23rd, 01, 03:41 AM
JohnZ's Avatar
The rag joint also has a copper strap from the upper flange to the lower flange that provides the ground path for the horn button; if the strap is broken or corroded, the horn won't work.
JohnZ
'69 Z28 Fathom Green
JohnZ is offline
post #10 of 11 (permalink) Old May 23rd, 01, 03:47 AM Thread Starter
Has anyone rebuilt this part ? It is much
cheaper to rebuild than to replace. $7.50
VS 53$.
Dave69Z is offline
post #11 of 11 (permalink) Old May 23rd, 01, 12:05 PM
Cool
i got my from GM,i pay only $25.00
68 RS ORIGINAL 327,350 trans.4 BARREL 650 CFM EDELBROCK,
HEADERS,2CHAMBERS FLOW MASTERS,3" PIPE.
12 BOLT REAR END 331 GEARS
PUMA68 is offline
