Forged or Cast - Team Camaro Tech
post #1 of 7 (permalink) Old Aug 16th, 00, 11:23 AM Thread Starter
Sorry if this sounds stupid but im not sure.
I bought my car with the motor already done
and the guy didnt know to many specs. im trying to find out exactly what i have. Here is the little I know . 400 block, world sportsman 2 heads, dual valve springs, push rod guide plates. I was wondering if aftermarket cams have a part # somewhere on them if so where? The guy said it was 515 lift int/exh. dont know the duration. i cant find a cam like that on comp's web site wich he said it was.Also is there a way of telling if you have forged crank or rods by looking at them .assuming the Oil pan off ,heads off?
Im also trying to figure out if this may be a
406 . I do know it runs hard !! ( eats mustangs and ram air t/a's) Thanks for any help. Also anyone going to the Woodward cruise in MI. This saturday ?
69' R/S LEMANS BLUE, 400, DELUXE INT, houndstooth, 12 bolt
12 bolt
R/S 350 is offline
post #2 of 7 (permalink) Old Aug 16th, 00, 04:03 PM
I'm not sure on the crank, get the casting #'s off it and check with a machine shop. The cam does have #'s on it. My car had been in storage since '89 when I picked it up two years ago, and the previous owner couldn't remember the valve lash (solid cam). So I pulled off the timing chain to look for the #'s, but they ended up being on the distributer side. I pulled the cam got the grind #'s and called crane cams (he knew it was a crane). They read off all specs from the cam card to me over the phone, then I was set.
Austin
Austin is offline
post #3 of 7 (permalink) Old Aug 16th, 00, 04:57 PM
Drake
Wink
From the few Comp Cams that I've seen,the # is usually stamped on the timing gear end.If you have the oil pan off,you could always pull the timing chain cover and gear to get the cam #.You could then go to Comp Cams web site,they list all thier cam cards on thier web site,but you need the # of coarse.
67 RS RAGTOP # matching
4X4 Chevy truck
4X4 Suburban
67drake is offline
post #4 of 7 (permalink) Old Aug 16th, 00, 05:10 PM
You can tell a cast from a forged crank at a glance. A cast crank has a sharp parting line, the parting line on a forged crank is flat, almost a hald inch wide
post #5 of 7 (permalink) Old Aug 16th, 00, 06:16 PM
Wink
JimM beat me to it...he's exactly right.
POP D TOP is offline
post #6 of 7 (permalink) Old Aug 16th, 00, 06:28 PM
David Pozzi
davidpozzi's Avatar
Lightbulb
Try looking at the front of the flywheel flange.
Where did the guy buy the cam? Maybe you can get them to look up the reciept and make you a copy. It should list the cam # there.
David's Homepage
67 RS 327
69 Camaro Vintage Racer
davidpozzi is offline
post #7 of 7 (permalink) Old Aug 17th, 00, 02:29 PM Thread Starter
Wink
Man this sight is great! Thanks alot for the
info guys . I probally wont tear anything apart until winter. ( having to much fun crusin) thanks again!
R/S 350 is offline
