How can I tell if its a true Z? - Team Camaro Tech
post #1 of 14 (permalink) Old Aug 17th, 00, 05:08 PM Thread Starter
Dan
I know someone selling what they claim to be a 68 Z28. It lacks the original engine, so how can I tell if its a true Z?
I know they came with 4 spd., posi, power disc brakes, special springs (leaf?). I've also heard there is a hole cut in the firewall for the cowl induction air cleaner. I havent seen it yet so does anyone have any tips?
(If my wife finds out I'm looking at another Camaro, I'm a dead man... I think I hear her coming.... gotta go!)
My RS Conv. 1
My RS Conv. 2
dadjad is offline
post #2 of 14 (permalink) Old Aug 17th, 00, 05:47 PM
The hole in the fire wall is for a cowl plenum air cleaner, very rare, most likely it would not have one. It would be located above the heater box, and rectangular in shape. Does it have gauges? If so what is the redline of the tach? There are other ways but I am not 100% sure what they are so I won't speculate, better no information than bad information. Good luck.
Steve R.
Steve R is offline
post #3 of 14 (permalink) Old Aug 17th, 00, 05:49 PM
On the driver's side of the firewall, there's a plate rivited to the car. It's about the size of a credit card and if you get the information off of there, there is a good chance that you can tell by that. I'm not sure on some of the codes for 68, i usu work with 69s, but someone correct me if i'm wrong; the x33 or x77 code on the trim tag confirms a true z28. also a 3/8 dia fuel line was used on hi po camaros and look for dual exhaust hangers and multi-leaf springs.
Joel
1969 Z28
LeMans Blue-White Stripes
#'s matching, P-O-P
shelbyz28 is offline
post #4 of 14 (permalink) Old Aug 17th, 00, 06:40 PM
Smile
If you don't have the build sheet or some other paper work that traces the car to the original owner , you'll have a hard time selling it as an original when it comes time to sell.
rick phillips is offline
post #5 of 14 (permalink) Old Aug 17th, 00, 07:18 PM
DjD
DjD's Avatar
Wheels should be 15X6, Power front disks were also part of the minimum Z package. Also rear springs are 4 leaf if my memory serves me correctly. X codes were a '69 thing, shelby got the Z ones right though. Gauges were options. You could get a Z without posi but it was recommended.
...Dennis
Topless'69
Camaros Limited Nor-Cal
[email protected]
DjD is offline
post #6 of 14 (permalink) Old Aug 17th, 00, 08:42 PM
From what I recall the x33 and x77 codes were for 69 Norwood cars.
Steve R.
Steve R is offline
post #7 of 14 (permalink) Old Aug 18th, 00, 12:22 AM
Bruce
off the subject, but i thought the fresh air intake (air cleaner attached to firewall), was only offered in 67 ?
am i thinking correctly ?
bruce
bruce69camaro is offline
post #8 of 14 (permalink) Old Aug 18th, 00, 01:02 AM
The wheels could have been changed, but look in the glove box for tire pressure info. If the sticker looks to be 32 year vintage and shows E70 x 15 for tire size, that's a good indicator. I preserved my original when refurbing the dash. Look for a 12 bolt rear too.
jacksz28 is offline
post #9 of 14 (permalink) Old Aug 18th, 00, 03:40 AM
DjD
DjD's Avatar
Bruce,
It was a $79 more for the Plenum air. I don't think it was available all year though...
...Dennis
Topless'69
[email protected]
DjD is offline
post #10 of 14 (permalink) Old Aug 18th, 00, 05:03 AM Thread Starter
Dan
Thanks all!
SteveR - What would that redline number be on the tach?
shelbyz28 - Didnt know about the 3/8 dia. fuel line, I'll check it out.
Bruce - Was the Plenum intake for Z's only, or was it available on any Camaro?
I'll ignore the x code thing as it sounds like it applies to 69 cars only.
Any other ideas or hints would be great!
dadjad is offline
post #11 of 14 (permalink) Old Aug 18th, 00, 05:10 AM
The cowl plenum air cleaner was available in 67 and 68 but like Dennis says it may not have been available all year. They came in the trunk so it may have never even been installed if it even came with one. I would love one of those air cleaners but they are so rare and they will probably never reproduce them. That would probably be the only repro part I would buy. Anyway look for matching number Muncie with the vin stamped into it even though it wouldn't make it a Z but at least the numbers matching trans. Muncie speedo cable routing was different. Look for tire sticker like jacksz28 mentions. Cowl tag does nothing to help verify any options in 68 except paint and interior. X codes are 69 Norwood only and only after a certain date I don't know off the top of my head. I think September sometime. Dual piston front disk brakes should be there. Doesn't have to have tach or guages. 68 is by far the hardest to verify. Good luck and let us know!!
68SS396 is offline
post #12 of 14 (permalink) Old Aug 18th, 00, 05:28 AM
Kurt S
Kurt S's Avatar
We've already done the work. See http://www.camaros.org/diffs68.shtml for the list of Z features.
Tire pressure sticker is a key thing to check. Also check the axle and trans stamped #'s. (See 'Decoding' on the CRG site for the locations.)
You can post the trim tag, VIN, and any codes you find on Tag Team and we'll tell you what the deal is.
Kurt S.
www.camaros.org
Kurt S is offline
post #13 of 14 (permalink) Old Aug 18th, 00, 10:45 AM
If it has a tach it would have a 6K redline, to be correct.
Steve R.
Steve R is offline
post #14 of 14 (permalink) Old Aug 19th, 00, 01:23 PM
No way to be 100% without the build sheet, or original documents, but there's a good chance if it has; 4 speed, 4 leaf rear springs, 15" wheels, 6K redline tick tock tach, 12 bolt, and paint stripes over spoiler stop befor the trunk deck.
'68Z-28 is offline
