Holley 3090 Info - Team Camaro Tech
post #1 of 5 (permalink) Old Aug 3rd, 01, 01:40 PM Thread Starter
I've searched and can't find any info on these carbs. I'm [pretty sure Im' getting the numbers right (choke horn). Anyone running one of these? I tried the holley website and they don't list it. They had to have made more than just one so if anyone knows anything (tuning, general info, cfm,ect.) I'd appreciate it.
Thanks, Dave
currently restoring my '67, 327, T-10,3.73 10 bolt
whitey is offline
post #2 of 5 (permalink) Old Aug 4th, 01, 05:59 AM
i don't see a 3090 listed here either,so double check your numbers,and try this site http://www.mortec.com/carbs.htm
My '68 Camaro
Doug G.
68 Camaro
406 ci.
[email protected] W/ 2.73POSI.
post #3 of 5 (permalink) Old Aug 4th, 01, 01:13 PM Thread Starter
Doug, thanks for the reply. I checked Morteck (as well as the rest of the web) and didn't see the number. The whole top of the carb lifts off - no side hung bowls, has vac. secondaries, dual feed and is aluminum in color. The numbers on the choke horn are R84011-1 with 3090 below it. Strange how there doesn't seem to be any listing.
whitey is offline
post #4 of 5 (permalink) Old Aug 4th, 01, 04:18 PM
JohnZ's Avatar
The list number you want to look up at the Holley site is R84011-1; the other number (3090) is the date code, which indicates it was a service replacement model, made around the end of October, 1970 (or 1980). It was never used in a production application. OEM production Holleys used a 3-digit date code.
JohnZ
'69 Z28 Fathom Green
JohnZ is offline
post #5 of 5 (permalink) Old Aug 4th, 01, 09:01 PM Thread Starter
Johnz, After relooking some holley sites I figured I'd look in my Summit catalogue. Sure enough on page 69 theres my carb- 4011 650 cfm., annular discharge boosters. Looks good. Funny thing though, its still not listed on the holley site.
The summit ad says limited quantities so mabey they've discontinued them.
whitey is offline
