How Many Quarts - Gear Oil - Team Camaro Tech
post #1 of 22 (permalink) Old Aug 3rd, 01, 07:38 PM Thread Starter
12 bolt, 3.73 posi to fill up rearend? Thanks.
ssdanny69 is offline
post #2 of 22 (permalink) Old Aug 3rd, 01, 08:49 PM
It should take between 2-3 quarts, fill it till it is even with the fill hole.
Brent
Prostreet 67 L-78 SS 396 project. Daily driven S-10 blazer: 355/700r4. 12.56 et. @ 108 mph.
prostreet L-78 is offline
post #3 of 22 (permalink) Old Aug 4th, 01, 04:40 AM
Don't forget to put in the bottle of GM limited slip differential additive with the gear lube.
Silver69 is offline
post #4 of 22 (permalink) Old Aug 4th, 01, 04:48 AM
This is a good topic. I have a slight leak from an old trac bar weld/crack. What type of gear lube do you use. How often do you add the posi lube?
Only 69 Z/28s
Garnet Red 30,000 mi
Glacier Blue
Rally Green new in 69
Stewie is offline
post #5 of 22 (permalink) Old Aug 4th, 01, 06:10 AM
stevo camaro's Avatar
Speaking of the posi additive, why do they insist on putting it in tubes shaped like toothpaste? No tip to reach the hole in the side of diff. case. I lost about a half tube awhile back trying to get the stuff in. I E-mailed the company and asked them to look into a better packaging design.
Sorry, had to vent. It still irritates me. Try not to spill any on the floor. LOL
67 SS 396,4-sp
67 RS 327,4-sp
72 RS 350/350
69 4X4 suburban 350,4-sp
73 3/4 ton 454/400
Stevo Camaro's Toy
Our Muscle Cars
stevo camaro is offline
post #6 of 22 (permalink) Old Aug 4th, 01, 06:30 AM
Freddie
stewie,
This has been discused much here. I like Amsoil series 2000 gear oil in a posi rear end. I have been using it for many years with very good results. It needs no additive for the posi. Others here don't like synthetics, but I think that may be because of some of the junk synthetic oils on the market. If you don't want synthetic oil just use any 80W90 gear oil and 1 bottle of GM 1052358 additive when ever you change your oil. If you have a Auburn posi use 2 bottles of the additive. If you want the best synthetic, click on my link below.
stevo,
Put the additive in the bottle with the oil and put it all in together. It's much easier.
'69 RS/SS396 pro street
427/4spd/9"
Byars Performance
High Performance Drive Train Parts And Service
www.lubedealer.com/biggearhead
big gear head is online now
post #7 of 22 (permalink) Old Aug 4th, 01, 10:03 AM
Rick
I used the Amsoil 2000 after reading a prior post by Big Gear Head. It took about 2 1/4 qts., no additive.
Rick Dorion
69 RS Conv,355,M20,4.10's
RickD is offline
post #8 of 22 (permalink) Old Aug 4th, 01, 11:04 AM Thread Starter
Thanks guys! Used 2 quarts plus the additive. Steve - you're right on the "tootpaste" tube! Just wanted to make sure that I was not under or over filling it.
post #9 of 22 (permalink) Old Aug 5th, 01, 08:59 AM
Wink
Big Gear Head, thanks, I feel like a weenie now. LOL But, in my defense, I was adding to a allready full diff. LOL
67 SS 396,4-sp
67 RS 327,4-sp
72 RS 350/350
73 3/4 ton 454/400
Stevo Camaro's Toy
Our Muscle Cars
post #10 of 22 (permalink) Old Aug 5th, 01, 09:34 AM
big gear head,
I assume you are using the 75W90 grade Amsoil series 2000 gear oil?
Will this gear oil work ok in a 12 bolt with an eaton posi unit?
Ricky
68/RS on Blocks...
Ricks68RS is offline
post #11 of 22 (permalink) Old Aug 5th, 01, 10:00 AM
Freddie
Rick,
Yes the series 2000 works well with the Eaton. No additive needed.
427/4spd/9"
Byars Performance
post #12 of 22 (permalink) Old Aug 5th, 01, 01:21 PM
I use Torco racing oil, 85/120 weight I believe, and Torco GM friction modifier. Tom's Differentials who I purchased my 12 bolt Eaton posi rear from would not warrantee the rear if I used anything else. Seems they really trust that oil. It's a bit pricey at $7/quart.
Joseph
Joseph is offline
post #13 of 22 (permalink) Old Aug 5th, 01, 01:36 PM
WHAT DOES ANYONE think about the redline rear end oil? good bad? Im just about to fill my stock tenbolt posi rear with some
cody is offline
post #14 of 22 (permalink) Old Aug 6th, 01, 12:22 PM
Well Steve what I do is this. I connect a rubber hose to the end of the gear oil bottle so I can hold the bottle anywhere there is room. I pour about half of the first bottle in then stop and mix the additive in with the rest, then fill it till it just starts to run out and it works pretty well. Thought I would share.
68 RS, Ash Gold,pwr brakes,pwr windows,Hounds tooth,355/T350,MSD 6AL,3200 stall Dynamic converter,3.31:1 posi,Autometer guage pod
[This message has been edited by CA420 (edited 08-06-2001).]
CA420 is offline
post #15 of 22 (permalink) Old Aug 6th, 01, 12:34 PM
mbrekke's Avatar
Excuse my ignorance, but what exactly does the additive do for you?
mbrekke is offline
