Dist. help - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 20th, 00, 12:07 PM Thread Starter
I hope this is right place to post this. I need an hei dist. with vac advance for my 70 z/28. don't want to buy new way to much $$$ for me right now.The motor is the solid lifter lt1 350
zgator is offline
post #2 of 6 (permalink) Old Apr 20th, 00, 03:25 PM
Wink
parts store they run about 90$,
junkyard about 25$
youll have to dent the firewall to get a factory hei in, alot of people buy kits that get rid of points but keep the distributor.
,i was thinking of getting a pt job at a napa just so i could get the discount
[This message has been edited by will stefan (edited 04-20-2000).]
will stefan is offline
post #3 of 6 (permalink) Old Apr 20th, 00, 04:17 PM Thread Starter
I thought that a 70 would not need any firewall mods because by 74 or 75 they all had hei?I cant't find any at my junk yards here in savannah because everybody gets them before I can get there
zgator is offline
post #4 of 6 (permalink) Old Apr 20th, 00, 08:07 PM
I installed a Pertronix electronic ignition
in my 69 Z28. As Will stated, it removes the points and eveything is under the cap. Took about 60 minutes to install and cost about $70. Revs to 6500+ rpm no problem and has required no maintenence.
Ed Ernst is offline
post #5 of 6 (permalink) Old Apr 21st, 00, 05:32 AM Thread Starter
When using thr pertronx do you still use your stock coil?
zgator is offline
post #6 of 6 (permalink) Old Apr 21st, 00, 06:42 AM
Yes, I am using the stock coil, dist cap and stock type plug wires. However, an aftermarket coil, wires, etc. might give the system even more efficiency.
Ed Ernst is offline
