Converting From Auto To Manual - Team Camaro Tech
post #1 of 4 (permalink) Old Jun 24th, 00, 01:17 PM Thread Starter
Wink
Is it hard to convert my 69 camaro into a manual trans. And Also i was wondering if i could put a 6 speed trans on it or will it fit on a small block 350
please help me
1969Camaro1969 is offline
post #2 of 4 (permalink) Old Jun 24th, 00, 03:26 PM
Try searching the archives on this subject, you will find plenty of information that way. After reviewing all of the previous posts that discuss this swap you can come back here and post some more specific questions. Check out this months (August?) edition of Super Chevy as they have an article on swapping in the T56.. Now that I think about it, it may have been Car Craft. Not sure but go to your newsstand now and look at those two magazines for sure.
Go69 is offline
post #3 of 4 (permalink) Old Jun 26th, 00, 07:15 AM
I am currently in the process of converting my 69. The hardest thing is finding all of the parts. You will need a new brake and clutch pedal with the bellcrank and all of the linkage. A flywheel, bellhousing, and clutch. I chose a four-speed Muncie for mine. I have heard that I might need a different driveshaft since the length between the trans & rearend might change. Also you will need to cut a hole in the floorboard for the shifter. I hope this helps and I have not left out very much. I should have mine done in a month or so.
[This message has been edited by GregSS396 (edited 06-26-2000).]
GregSS396 is offline
post #4 of 4 (permalink) Old Jun 26th, 00, 07:30 AM
Red face
OOPS!!! I forgot the most important part the shifter and the linkage.
