Installing front shocks??? (weight transfer??) - Team Camaro Tech
post #1 of 6 (permalink) Old Jun 25th, 00, 09:48 AM Thread Starter
Chris
I would like to install some shocks in front. I figured some KONI shocks, yet I'm not sure how I would set them for better weight transfer to the rearend. Right now I have 50/50 shocks in the back. So what would be good for the front? i.e. ??/??.
Will I need a ring compressor to install these front shocks, or will I be able to install these shocks on a hot Texas day in my garage? I've installed back ones, but I think I still have the original shocks in the front.
Watcha think????
Procharged69 is offline
post #2 of 6 (permalink) Old Jun 25th, 00, 10:08 AM
If it a first gen. camaro its not a hard job, as long as the top nut comes off ok. If your looking for straight line launch I would go with 90/10.
Austin is offline
post #3 of 6 (permalink) Old Jun 25th, 00, 10:19 AM Thread Starter
Chris
Sorry, what was I thinking?? Duhhhhh!!
It's a 1969 camaro, with a 468, TH350.
post #4 of 6 (permalink) Old Jun 26th, 00, 04:32 PM
Best way to remove the top nut is a deep 9/16 socket and 12 - 18 inch extension.
Slip the socket and extension over the nut and start bending it back and forth, about 15 - 25 times and the shock stud will break under the nut, no hassel trying to hold the shock stud while twisting the nut.
I would get some new shock nuts for the bottom end ( GM dealer Stock). You won't need to to compress the springs and should be able to handle it on a Sat. afternoon.
Its about a three beer job.
Rob.Canada is offline
post #5 of 6 (permalink) Old Sep 17th, 06, 06:51 PM
Thomas
Re: Installing front shocks??? (weight transfer??)
Impact wrench if you've got one. So easy it makes you giggle.
tubergonz is offline
post #6 of 6 (permalink) Old Sep 17th, 06, 07:28 PM
Andy
Some competition engineering 90/10 adjustable shocks would be a good shock for weight transfer much cheaper too.Very easy to install don't need to do anything with the springs to change the shocks.I just noticed this is a pretty old post I guess you got it figured out by now though!
67 R/S convertible Nantucket blue deluxe interior orig.
67 rs-ss coupe 565BB-400turbo streetcar/racer project 1.43 60ft 9.683 140.91
2x67rs/ss is offline
